 Forum index » Clavia Nord Modular » G2 Patches - Completed » Synth
Wheel Repeat
Page 1 of 1 [2 Posts]
jdd
PostPosted: Tue Apr 11, 2017 9:59 am    Post subject: Wheel Repeat Reply with quote  Mark this post and the followings unread
Here's a fun little patch. It's partly inspired by the band Papadosio, who play a lot of solos on analog synths where they vary the rate of a square or sawtooth LFO up and down throughout the solo.
Use the mod wheel to control the repeat rate.
Tap the sustain pedal to briefly disable the repeat effect.
JD
Wheel Repeat.pch2
Repeating envelope with mod wheel & sustain pedal control.
 Filename:  Wheel Repeat.pch2
 Filesize:  1.8 KB
 Downloaded:  4008 Time(s)
jdd
PostPosted: Wed Apr 12, 2017 6:05 pm    Post subject: Marimba Repeat Reply with quote  Mark this post and the followings unread
The next step is the famous Lowrey Organ "Marimba Repeat" feature used in Baba O'Riley.
The notes B,C,C#,F,F#, and G repeat on the "on" 16th note, while D,D#,E,G#,A, and A# repeat on the "off" 16th. So, given a note number from the keyboard, how do you get its pitch class? This is the "modulo division" column: you use a note quantizer to round it down, and then subtract the rounded-down value from the original value. Normally you'd set the quantizer to 12 notes, but here we can use 6. Apply some offsets before and after the division (for reasons I can't quite explain), then multiply the result by 4 so that it can be used to control a sequencer.
The repeat circuit here is a lot like the Wheel Repeat circuit, but an 8-counter (shorted to make a "2-counter") distinguishes the "on-beat" pulse from the "off-beat" pulse.
I didn't put a lot of thought into the organ sound here. It's just one I had handy. The EQ in the effects section has a lot to do with the final sound; it's inspired by someone else's patch from the internet.
For Baba O'Riley, choose variation 1 and set the global clock to 238 BPM.
Marimba Repeat.pch2
 Filename:  Marimba Repeat.pch2
 Filesize:  3.44 KB
 Downloaded:  4035 Time(s)
