337is
Joined: Nov 02, 2010 Posts: 21 Location: Berrien Springs MI
Posted: Thu Dec 19, 2013 1:33 pm Post subject:
Working Nord Modular G1 editor on OSX Mavericks 10.9.1 |
Reporting my success for others who may be having issues running their early Nord Modulars.
http://www.youtube.com/watch?v=B3_H1vf-ssY&feature=share&list=UUrP4rvYdVvBUDhnOkj2bo7w
Nord Modular G1 editor 3.0.3 running on Windows XP Pro SP3 VL MSDN via VirtualBox 4.3.6 on an iMac running OSX 10.9.1. Using iConnect MIDI2. The iConnect makes things painless. I'd used the Midisport 2x2 for years, but it became less reliable in virtualized settings. The patch is my favorite one I have ever made for it ... an imitation of the crickets in the backyard of the home I grew up in.
This was a breeze to set up and I'm not overly techie ... |
jonah
Posted: Wed Jan 01, 2014 7:15 pm Post subject:
i tried virtual box and i get an out of memory error in the g1 editor. from searching online i guess it has to do with the audio drivers, but it seems like i can't remove them.
did you run into this?
in your virtual box settings what is the audio driver you're using? thanks.
back to os9! honestly i might try sheep shaver or some other os9 emu at some point because i like the way os9 manages windows compared to windows. |
337is
Posted: Thu Jan 02, 2014 6:31 am Post subject:
Hey Jonah,
I didn't change any of the default settings for the drivers. When I tried using my Logitech MIDISport USB 2x2 I had all sorts of driver issues in the past. Moving to a modern iConnectMIDI2 which has class compliant drivers seems to be what really made things go easily for me. Literally plug and play with ZERO configuration.
When I get back home I'll double check my settings and share them with you here. Good luck! |
Audio files: 19
Posted: Thu Jan 02, 2014 3:37 pm Post subject:
This is great news if you have got it working? The iConnectMIDI is the only thing left on my musical want list.  _________________ ACHTUNG!
337is
Posted: Sat Jan 04, 2014 4:34 pm Post subject:
This is absolutely working for me. My Audio settings in Virtual Box are:
Host Driver: CoreAudio
Controller: ICH AC97
I hope this helps you get up and running. |
jonah
Posted: Sun Jan 12, 2014 11:24 pm Post subject:
thanks.
i'm going to try re-installing windows and seeing if that fixes it. if i choose ICH AC97 in VM it says it can't find drivers, but i'd think removing the hardware from the device manager would fix it anyway. uhhg i didn't miss windows.
i wonder if it's because i have a mac book pro - different audio hardware than the iMac. |
337is
Posted: Mon Jan 13, 2014 7:24 am Post subject:
| jonah wrote: | | i wonder if it's because i have a mac book pro - different audio hardware than the iMac. |
I don't think so because I run the exact same setup on my Macbook Pro as well. The key for this working, imho, is using the iConnectMIDI2 ... it takes zero configuration and systems simply recognize it. Good luck! I hope you can get it up and running.  |
337is
Posted: Thu Aug 28, 2014 11:40 am Post subject:
Subject description: Now working on OSX 10.9.4 |
Just bumping this thread with updated information that the same setup which I described above is still working flawlessly for me using an updated OSX 10.9.4 and Oracle VirtualBox 4.3.14 r95030. Keep on patchin'!  |
337is
Posted: Sat Jul 29, 2017 5:40 am Post subject:
Another update to confirm that this setup works with macOS Sierra 10.12.6 (16G29) with VirtualBox 5.1.26 r117224 (Qt5.6.2).  |
337is
Posted: Sat Jul 29, 2017 9:42 am Post subject:
Sorry for the double post today ... I just realized there have been other devices in my chain, so clarifying exactly how this is currently working on my system:
Update: 07/29/17: Confirmed working with with macOS Sierra 10.12.6 (16G29), VirtualBox 5.1.26 r117224 (Qt5.6.2), iConnectMIDI2+ 1.1.0 firmware, and iConnectivity iConfig Version: 4.2.6. |
Former site admin
Audio files: 353
Posted: Sat Jul 29, 2017 11:37 am Post subject:
| Thanks for your reports - I've stickied the topic - for .. you know .. just in case :) |
337is
Posted: Tue Jul 10, 2018 1:39 pm Post subject:
Thanks for the sticky!
Checking back in to report this is still working with this setup:
Update: 05/31/18: Confirmed working with with macOS High Sierra 10.13.4 (17E202), VirtualBox 5.2.12 r122591 (Qt5.6.3), iConnectMIDI2+ 2.0.0 firmware, and iConnectivity iConfig Version: 4.2.7 or Auracle v1.2.0-309. |
docsample
Posted: Wed Jul 11, 2018 3:41 pm Post subject:
| i never had problems running the editor in wine under mac osx. |
Bambrose
Former site admin
Audio files: 353
