Coming up on Radio 1 at
My Alesis Andromeda A6 Editor & VST
Page 4 of 4 [88 Posts]
kcoul
PostPosted: Fri Nov 17, 2017 12:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
Pollux - I am curious if you have heard of JUCE before:
https://juce.com/doc/tutorial_create_projucer_basic_plugin
It makes adding a fantastic looking front end to a VST incredibly easy with plenty of prefab'ed UI components to choose from. Wiring them up to what you already have should be pretty easy, and for a niche target audience it's totally free.
I've also built a ton of hackintoshes so happy to recommend on options there to build for Mac.
Pollux
PostPosted: Sun Nov 19, 2017 1:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
I have heard of & looked into JUCE. While it can make fantastic GUI's easily, it lacks in the ability to handle MIDI & Sysex & Standalone App's IIRC (although I could add that myself...). It also costs a whopping $1000 for a license to sell one's application... Rolling Eyes
Also thanks for the offer! I have a Hackintosh running in a VirtualBox VM, with xcode installed...I'm just so clueless when it comes to mac ANYTHING. Developing, debugging, troubleshooting, configuring...it's all just so maddening to me lol
kcoul
PostPosted: Tue Nov 21, 2017 12:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
Actually JUCE is totally free when revenue is under 50k!
https://juce.com/get-juce
It can definitely handle MIDI & Sysex & build standalone apps without any problem at all! It's possible that much, much earlier versions lacked some of those features, but these days it is a real powerhouse in the VST and audio app building world, second to none I'd say!
I'd be happy to help with info on building for Mac. I only know the bare minimum needed to build for Mac and iOS as I am also generally maddened by the overpriced Apple walled garden. I have built cross-platform VSTs and audio apps so I could point to some key info on how to minimize the hassle.
I say this as I am looking into joining the handful of people building tools for combining the A6 with modern DAWs and computers... I had my hopes so high when Ableton said they would be adding sysex to Live 10. Then devastated to find out they were still neglecting NRPNs. I don't get it as all the best hardware has no choice but to use them since the MIDI spec has so few high resolution CC lanes, and even the 7bit lanes run out pretty darn fast (my Supernova 1 and 2 eat up all the CC lanes and then use up NRPN for the rest... the best compromise I suppose...)
So I want to release a tool that will at least allow Live users to pick out the NRPN parameters they want to automate, translate them over to CCs, record them, automate them, and then play them back translating back to the right NRPNs. It's a bit maddening this is needed but for some styles of music Ableton is really far and away the DAW to use...
I want to get the most out of my Supernovas and Andromeda and keep Live as my DAW so there is really no other way to do this... Anyhow I will go the Max4Live route so it will be a bit less hassle than coding a full VST at least..
ProFete
PostPosted: Sun Dec 10, 2017 11:27 am    Post subject: Reply with quote  Mark this post and the followings unread
hello Pollux
your vst work great in reaper
but impossible to make it work in sonar platinum,
he is reconized as an audio effect
do you know about it?
thank
and thank for your job Smile !
View user's profile
ProFete
PostPosted: Sun Jan 13, 2019 3:09 am    Post subject: Reply with quote  Mark this post and the followings unread
anyone make it work with ableton 10 please ?
i have tried virtual port and routing with midiox without luck
View user's profile
sunny pedaal
Audio files: 12
PostPosted: Tue Jan 29, 2019 8:49 am    Post subject: Reply with quote  Mark this post and the followings unread
what about bidule ?
Pollux
PostPosted: Fri May 01, 2020 11:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
BIG NEWS. I report back some AWESOME development progress. I added (but not-yet released) the MIDI CC NRPN algorithm to my Andromeda A6 VST.
I successfully used my Andromeda VST in Ableton Live 10.1, and Cubase 10.5. The parameters are now automate-able as a VST within Ableton Live 10.1, Cubase, and every(?) DAW now! See screenshots for proof!
( Previously, I reported I got MIDI CC NRPN control working in Ableton Live (9), but discovered it was buggy because Ableton Live 9 was trying to be too smart, and was filtering out 2 of the 4 MIDI CC NRPN messages needed to control Andromeda value changes.
God bless a gentleman named Marcus -- who emailed me yesterday, and let me know that Ableton Live 10.1 no longer filters out duplicate MIDI CC NRPN messages (which the Andromeda needed). So I tried the VST in Live 10, AND OMGOMGOMGOGMOGMOMG IT WORKED. My, and others dreams have been renewed. See attached GIF!
I'm quite a busy and scatterbrained person, juggling an insane amount of hobbies and projects at once --- so I hope to prioritize this and release this soon. I will need to go through every parameter one by one --- making sure every parameters works correctly in NRPN mode in Ableton Live 10, and Cubase, and adjust accordingly!
p.s. Anyone know anyone with a spare Cubase 10.5 or Ableton 9-> upgrade 10 license they can donate, for, research? lolz Looking at my studio, you wouldn't believe me If I told you I couldn't afford it right now Embarassed
 Filesize:  50.06 MB
 Viewed:  703 Time(s)
 Filesize:  6.17 MB
 Viewed:  750 Time(s)
Pollux
PostPosted: Sun May 03, 2020 9:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
Just released an updated version 0.9.0 -- which now has a selectable MIDI CC NRPN mode. Everyone can enjoy automating the entirety of your Andromeda with envelopes lanes within your DAW's now, sluts Twisted Evil
statlerw
PostPosted: Tue Sep 22, 2020 5:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
You are a god amongst men
Pollux
PostPosted: Wed Jun 23, 2021 5:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
Awwwwwwwwwww yeah, look whats in progress: Started working on like the 4th re-write at this point. Because I'm pretty sure I got most of the Andromeda parameters automated at this point -- except the FX pages -- I started re-writing it from the ground up, so everythings laid on infront of you on one screeen. Finally Smile This is how I had everything originally (before offering it to the public, but I lost that versions source code). Feels good. This is the rough layout. Re-skinning it will be easy. I can give it the same background and knobs as the andromeda, or whatever.,
 Filesize:  106.04 KB
 Viewed:  529 Time(s)
Chuffy
PostPosted: Sat Jan 31, 2026 2:39 am    Post subject: Editor Reply with quote  Mark this post and the followings unread
Is this dead now? The link doesnt work...
Audio files: 267
PostPosted: Mon Oct 26, 2026 3:48 pm    Post subject: Re: Editor Reply with quote  Mark this post and the followings unread
I tried the link in the first post of this topic and it does load.
Analog Dessert
PostPosted: Thu Nov 05, 2026 5:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hey everyone! Pollux here (original thread author!) Smile. Long post, well worth the read, I promise Twisted Evil It's been a LONG time since I started this thread and began developing my Andromeda A6 editor. I've got some pretty huge updates to share!
I've completely rebuilt the editor, added some features I'm really excited about, and even developed an entirely new synthesizer inspired by the A6.
Andromeda Editor 2.0 is here! MacOs / Windows / Au / Auv3 / VST3
The editor has undergone a major overhaul, with a completely redesigned GUI, standalone Mac and Windows applications (MAC SUPPORT FINALLY!!!), VST3/AU/AUv3 plugins, and much deeper integration with the Andromeda.
Some highlights:
  • New GUI. A completely redesigned, tabbed interface that makes navigating the Andromeda's hundreds of parameters much easier.
  • Full 16-part Mix Mode editing. This was a BIG one. Load an entire Mix and edit all 16 parts, each with its own dedicated Program editor and Mix settings. Essentially 16 complete synthesizer editors inside a single plugin. Insanity. Smile
  • Actual Andromeda parameter values. No arbitrary 0–65,535 or normalized 0.0–1.0 values where meaningful units are available. Actual filter frequencies in Hz, LFO rates, envelope times, clock divisions, etc., just like the hardware. I spent ages reverse-engineering those parameter mappings for the original editor years ago. PRE-AI! Hehe.
  • Bidirectional MIDI synchronization. Turn a knob on the hardware and the editor updates. Change something in the editor and the hardware follows.
  • Full patch librarian. Import/export SysEx patches and banks, organize and rename sounds, and transfer them back to the Andromeda.
  • DAW automation and parameter randomization. Randomization sets, min, maxes, ranges, etc. A pretty comprehensive randomization system.
Everyone who purchased an earlier version has already received the update completely FREE!. Thank you to everyone who's supported this project over the years!
Posted Image
Posted Image
Now something genuinely new: program your Andromeda with natural language!
Im the first, and only developer, that Im aware of, adding built in MCP (Model Context Protocol) server(s) to the Andromeda Editor (and all my software plugins/synthesizers now)
This allows compatible AI assistants like Claude Code, Codex, and others to understand and directly control the Andromeda's parameters and synthesis architecture. Not just suggest settings. Actually PROGRAM your physical Andromeda!
Imagine describing a sound:
"Create a warm, evolving analog pad with two detuned oscillators, a resonant low-pass filter, slow modulation, and subtle pitch drift."
Using the MCP of my Andromeda Editor, assistants will deeply understand everything about the Andromeda, and my Andromeda Editor, and all the parameters inside of it and how to use them --- it figures out how to construct it using the A6's oscillators, filters, envelopes, LFOs, and modulation routings, then programs the synth through the editor.
Play it, tweak it yourself, or ask the assistant to keep refining it. I think it opens up some fascinating possibilities for sound design, especially with the A6's ridiculously deep modulation architecture.
And finally... the reason this update took so long: I built an entirely new synthesizer.
While working on the Andromeda Editor's new GUI, I went down a rather enormous rabbit hole. I've always loved the A6's Mix Mode architecture, combining multiple complete synthesizer Programs into one sound. I wanted a software equivalent, but without the hardware limitations.
What if I could add another oscillator? Another filter? Another envelope? Or an entirely new synthesizer inside my existing patch?
What if I could just click "+" and keep building?
That idea became Oscillato, a synthesizer I've spent years developing. And I might be biased, but I genuinely think it's one of the best-analog-sounding and definitely the most powerful synthesizers I've ever used. It's replaced my room full of analog synths Shocked !
Oscillato takes the Andromeda's Mix Mode concept much further:
  • Every layer is an entire polysynth, with its own oscillators, filters, envelopes, LFOs, and modulation. Stack entire synthesizers inside a single patch.
  • Need more? Just click +. Add oscillators, filters, envelopes, or entire synthesizer layers. I've built patches with hundreds and even thousands of oscillators.
  • Analog-modeled oscillators and filters developed through years of studying my Alesis Andromeda A6 and Roland SH-2, alongside wavetable, FM, sampling, and other synthesis capabilities.
But here's what I think Andromeda owners will find particularly interesting... Oscillato can IMPORT ANDROMEDA A6 PATCHES!
You can import an Andromeda SysEx patch, or retrieve one directly through MIDI, and Oscillato converts it into a playable software patch. I've spent an enormous amount of time translating the A6's parameters, oscillator behavior, filters, envelopes, and modulation into Oscillato's engine.
Some patches translate almost perfectly. Others are very close, while some still need work. It's an ongoing project, not a perfect 1:1 emulation, but the results can be ridiculously close!
And once you've imported an Andromeda patch, you're no longer limited by the Andromeda's hardware architecture.. Add six more oscillators. Another filter. More modulation. Stack a completely different synth on top. Your original A6 patch becomes the starting point for something much bigger.
Oscillato also supports MCP! Describe a complex sound in natural language to a LLM or AI assistant, one you only thought possible from your imagination or dreams, and watch an AI assistant build the patch right in front of you.
[img]https://analogdessert.com/wp-content/uploads/2026/11/oscillato-hero-v110-showcase-20261117.webp[/img]
And just to clarify, I'm not interested in AI-generated music. I'm interested in new ways to program synthesizers and bring the sounds in your imagination to life. You're still the musician making the music.
Anyway, I wanted to share what I've been working on with everyone who followed or supported the original editor all those years ago.
The Andromeda is still one of my favorite synthesizers ever made. A huge part of what went into Oscillato came from spending countless hours understanding that wonderful, ridiculously complicated instrument. (And even Oscillato will never replace the 0% CPU usage of hardware synths Very Happy )
Andromeda Editor: https://analogdessert.com/downloads/andromeda-editor/
Oscillato: https://analogdessert.com/downloads/oscillato/
Oscillato Demo Reel: https://www.instagram.com/p/DfTMrmMBUxF/
I'd love to hear feature requests for the editor, feedback, ideas... I'm actively developing both projects, almost full-time again Smile
Thanks again to everyone who's supported my work over the years!
Cheers!
Pollux / Analog Dessert
p.s. Quick Oscillato update: I ported over 10 new modular effects from my other baby, Stepsicle. And with this update, things got a little out of hand. Again. Smile
The new effects aren't limited to the end of a signal chain. Want a BBD delay on one oscillator before it even hits a filter? Patch it in. Want two oscillators, a filter, and another effect feeding the same reverb? Go for it. You choose the combinatorics. Like a modular Smile
Here's Tape Daze, a soft pad under a self-oscillating filter lead with ping-pong delay.
Watch the demo
Download the patch
