Help with stripboard layout...
Page 6 of 6 [140 Posts]
Goto page: Previous 1, 2, 3, 4, 5, 6
Late_to_the_party
PostPosted: Wed Oct 25, 2017 6:55 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks PHOBoS.
My the output is a little noisy. So I'd like to fix it.
However, I wired according to Eric Archer's layout. See image below...
Any idea why this kills the output when I connect these three components to the ground?
 Filesize:  530.67 KB
 Viewed:  990 Time(s)
Audio files: 730
PostPosted: Wed Oct 25, 2017 2:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
hard to say but something must be wrong if it works otherwise.
Could it be that you used a 220nF capacitor for C1 instead of 220pF ?
The Golden Shrimp Guild
Late_to_the_party
PostPosted: Wed Oct 25, 2017 2:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks PHOBoS...
I am a complete wally. I had failed to connect C1 to C11. Fixing that problem meant when I connected the 'missing' ground to C1, R20 and R25, it worked perfectly.
Now I have a fully working clone. No noise, loud as hell, beautiful long decay. Thanks for everyone comments, this forum enabled me to get this far.
I think I will switch to stripboard over perf board for the other modules, to avoid any more missing links.
I feel I have only just scratched the surface here though. Really want to mod this kick with an OVERDRIVE pot. Anyone have any ideas?
Also, I have just tied Accent to +15v, Is there any point adding a pot to it to vary the 'accent'?
I'm also going to have to make a sequencer, having to press a button for a BOOOOOOOM is getting in the way of making music.
artilect99
PostPosted: Thu Oct 11, 2018 7:52 am    Post subject: Reply with quote  Mark this post and the followings unread
Hey all -- just thought I'd post my own working copy of the layout in case it's helpful to anybody building this. The original layout by Minus underwent a number of changes over the course of this thread (notably a missing cut between R26 and C4 as well as other minor tweaks) which are incorporated here.
The potentiometer diagram was added because I originally wired the pots backward (Wiring the pots as they are numbered in the Eric Archer schematic will result in them being reversed).[/img]
 Filesize:  745.81 KB
 Viewed:  1291 Time(s)
RyBowk
PostPosted: Mon Dec 03, 2018 6:07 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi, so is this confirmed with the bom at beginning of this thread? Thanks Ryan
artilect99
PostPosted: Mon Dec 31, 2018 3:08 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi ryan -- yes, it uses the original BOM. No components added, just a missing cut on the board and some tweaks (like the output needing to be moved on the top left etc). The tuning mod would require another pot if you replace that resistor.
Incidentally, if anyone is building this as a Eurorack module, I found it works great to just use a jack for the accent, and tie the +V into the switch of the jack, so it gets normalled +12v if nothing is plugged in. Then if you feed this jack CVs it acts as volume control / accent. Jack for trigger in can take a normal 5v gate or trigger pulse in this setup, and longer gates give a more overdriven sound.
RyBowk
PostPosted: Mon Dec 31, 2018 12:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
I now have this built and it sounds great, especially with the tune mod.
RyBowk
PostPosted: Tue Jan 01, 2019 2:05 am    Post subject: Reply with quote  Mark this post and the followings unread
I did have it working perfectly. After using it for some time I turned it back on and now the kick is at a constant higher pitch? Does anyone have any clue as to why? I have even tried taking the tune mod away and putting the original resistor back. I’m stumped!!
RyBowk
PostPosted: Tue Jan 01, 2019 12:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
All sorted, turns out a transistor leg wasn’t soldered properly.
artilect99
PostPosted: Wed Jan 02, 2019 6:18 am    Post subject: Reply with quote  Mark this post and the followings unread
Glad to hear you got it sorted out. I'm doing the snare next, I just have to figure out a decent way to mount a stripboard to a 6u eurorack panel (brackets maybe?). Right now my 808 bd is just hanging loose inside my case.
RyBowk
PostPosted: Wed Jan 02, 2019 11:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
After building the kick I just have a cymbal left to do. What I have done for mounting is use a piece of right angle plastic, bolted the strip board to it and used the potentiometers to mount the plastic to the panel. The panel size I have used is the size of the Moog Mother as I have built a trigger sequencer also. I think I will build it into its own case. Thanks Ryan
Audio files: 730
PostPosted: Thu Jan 03, 2019 7:46 am    Post subject: Reply with quote  Mark this post and the followings unread
keep in mind that if you plug the cable in that for a short moment the +12V will be connected to the cable and thus whatever it is plugged
into on the other side. Modules should have protection on the outputs but I'd recommend adding a resistor in series with the +12V.
on a side note, did you make any changes for eurorack as it seems to be designed for -/+15V ?
artilect99
PostPosted: Thu Jan 03, 2019 8:51 am    Post subject: Reply with quote  Mark this post and the followings unread
Good call Phobos, that hadn't occurred to me... what value resistor should work there do you think?
no problem whatsoever running it off 12v, although it does affect the character of the sound to some degree. Running it at 15v seems to give the best sound and headroom, but 12v is fine.
I'm running mine into a Strymon deco for some tape saturation and compression and it sounds f*kin glorious. banana banana
regarding mounting, I was thinking of using some of Ken Stone's pot mounting rail PCBs (although they are 1" spacing if I remember correctly... might be tight) and attaching the board perpendicularly via a right-angled pin header.
Audio files: 730
PostPosted: Thu Jan 03, 2019 1:30 pm    Post subject: Reply with quote  Mark this post and the followings unread
I usually use 1K although it depends a bit on the circuit.
Based on the schematic posted on the previous page I think that should work fine for this.
maybe I will give this one a try someday.
lysergist
PostPosted: Mon Feb 17, 2020 5:06 am    Post subject: Reply with quote  Mark this post and the followings unread
Another BOM update : R26 should be a 100K, not a 4k7
