 Forum index » Instruments and Equipment » Sequencers
Beatstep pro cv ground
fuji
PostPosted: Fri Feb 15, 2019 1:10 am    Post subject: Beatstep pro cv ground Reply with quote  Mark this post and the followings unread
Hi i would ask a question, I recently purchased a beatstep pro to control both ms20mini and some diy vco i made (verbos 258 wich is a buchla 258 clone). With ms20 it works fine(H\v mode), but with 258 it is not working as it should becouse waveform is totally modified when plugged with BSP, and I noticed that if i plug the sleeve of the mini jack coming out of the BSP cv in the ground of my diy modular system it doesnt work (sounds stops), and both ms20mini and 258s only need tip connection to work with BSP. So my question is how can BSP send cv (0 to 10v) with only one connection in the trs and not sending the “0 volt” reference?
View user's profile
