Brief maintenance shutdown at 10:00 PM EST - 0400 UTC
808 Bass Drum Clone Eagle PCB & CNC Gcode
Page 3 of 3 [56 Posts]
Goto page: Previous 1, 2, 3
kropo
PostPosted: Tue Mar 19, 2019 5:00 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi
Any ideas on the ferrite beads? I saw on some topic that 10r or was it 10k resistor or was it capacitor could do it also?
Regards
Jake
PostPosted: Tue Mar 19, 2019 6:44 am    Post subject: Reply with quote  Mark this post and the followings unread
A 10R resistor is pretty useless, and if the module draws any significant current it makes the rails unstable.
I doubt a bass drum voice *does* draw much current, but if I didn't have ferrites I'd just put in a wire jumper. It's just HF isolation on the rails, it's not as critical as even the bypass caps.
kropo
PostPosted: Tue Mar 19, 2019 6:52 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi
Thanks, is there any specific ferrite value that should be used?
Regards
Jake
PostPosted: Tue Mar 19, 2019 8:13 am    Post subject: Reply with quote  Mark this post and the followings unread
IME ferrite beads are ferrite beads, and I've never seen anyone specify a particular part/imedance/etc. It just needs to be one that fits the space available.
kropo
PostPosted: Tue Mar 19, 2019 9:11 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi
Thanks for helping. I saw different kind of values on Mouser but I’ll just order something for this.
Regards
Jake
kropo
PostPosted: Sat Jan 18, 2020 3:28 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi
Question about the midi cv drums, can this be used with normal midi devices or do I need to have something else? Not familiar with the sysex messages. Can I example trigger these with my MPC via midi?
Regards
Jake
