Brief maintenance shutdown at 10:00 PM EST - 0400 UTC
808 Handclap (almost there)
Page 1 of 1 [15 Posts]
jbeuckm
Audio files: 9
PostPosted: Thu Aug 27, 2015 5:46 pm    Post subject: 808 Handclap (almost there) Reply with quote  Mark this post and the followings unread
The simple noise envelope is working but the clackity clack is not happening. Help me debug!
I substituted the BA6110 but did not build the current mirror as suggested here: http://www.firstpr.com.au/rwi/dfish/TT-303/click-fix/
Could that be the problem?
Eagle files are here:
https://github.com/jbeuckm/808-Handclap
bad_808_clap.mp3
 Filesize:  44.93 KB
 Duration: 0:02
 Viewed:  2704 Time(s)
 Filesize:  94.58 KB
 Viewed:  1422 Time(s)
LFLab
PostPosted: Fri Sep 04, 2015 4:23 am    Post subject: Reply with quote  Mark this post and the followings unread
Started to have a look at this one in Eagle, I used your schematic, but started to reroute to have all resistors lying down, a bit more compact, and adjustments for parts which I have in my bin.
I'll try to spot mistakes before committing this to an iTEAD order Very Happy
Did you see these?
Yocto build tips
E-licktronic (Yocto) errata
jbeuckm
Audio files: 9
PostPosted: Fri Sep 04, 2015 7:14 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks! I'm pretty excited to get home and flip C144... There are plenty of things to measure and try here.
jbeuckm
Audio files: 9
PostPosted: Tue Apr 26, 2016 9:03 am    Post subject: Reply with quote  Mark this post and the followings unread
@LFLab Any luck? I have restarted this layout from the Yocto eagle file. I probably had a bad connection or wrong value on my first version. Also, I am moving to 2N390x transistors this time to avoid any pinout variations. I'm doing the reverb mod too.
LFLab
PostPosted: Tue Apr 26, 2016 9:17 am    Post subject: Reply with quote  Mark this post and the followings unread
I actually did a layout....for the 909 clap Very Happy
Nothing going on on my end on the 808 clap.
jbeuckm
Audio files: 9
PostPosted: Tue Apr 26, 2016 9:36 am    Post subject: Reply with quote  Mark this post and the followings unread
Very similar circuit. Which OTA did you use?
LFLab
PostPosted: Tue Apr 26, 2016 11:36 am    Post subject: Reply with quote  Mark this post and the followings unread
CA3080, usually I'd replace this with 13700, but for the life of me I couldn't figure out what to do with the other section, and I do have quite a few of them around.
It only exists in Eagle now though Smile I used hexinverters neinohnein schematic, so that should be good.
I have some grief with the Yusynth Quadrature LFO to deal first Crying or Very sad
jbeuckm
Audio files: 9
PostPosted: Tue Apr 26, 2016 2:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
Oh that's easy - use the other half of your 13700 to CV the reverb level Wink
jbeuckm
Audio files: 9
PostPosted: Wed Apr 27, 2016 8:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
Woohoo - verified! I had to change C140 to 27n to get separated hits (2n7 in the service manual). This has reverb level on a 16mm edge pot. Requires separate noise source.
https://github.com/jbeuckm/808-Handclap/releases/tag/v0.1
808_clap.mp3
 Filesize:  538.81 KB
 Duration: 0:14
 Viewed:  2655 Time(s)
 Filesize:  51.25 KB
 Viewed:  1067 Time(s)
LFLab
PostPosted: Thu Apr 28, 2016 3:28 am    Post subject: Reply with quote  Mark this post and the followings unread
Very nice! cheers
ADMST
PostPosted: Mon Dec 12, 2016 12:38 am    Post subject: Reply with quote  Mark this post and the followings unread
Man, your work is inspiring! Will this design run at +/- 15v ??
jbeuckm
Audio files: 9
PostPosted: Tue Dec 13, 2016 8:08 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes. The original was 15v afaik. I think I actually used a +-15V power supply on mine through a euro connector.
ADMST
PostPosted: Tue Dec 13, 2016 11:18 am    Post subject: Reply with quote  Mark this post and the followings unread
Amazing. Thank you!
artilect99
PostPosted: Wed May 29, 2019 4:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
Sorry for the noob question, but I've never had a PCB fabbed before. How exactly does one go about getting a PCB made from files such as these? Do I need eagle in order to convert them to gerber files?
lilpaula87
PostPosted: Mon Sep 12, 2022 3:51 am    Post subject: Reply with quote  Mark this post and the followings unread
Wow I’m really interested in this project but I already have a midi to cv and a cv to trigger module. There’s a way to slightly modify this pcb to add an external input for trigger and accent?
