Coming up on Radio 1 at
Modulator ESP on Adventures In Sound
Vactrol CV control
Page 1 of 1 [3 Posts]
lilpaula87
PostPosted: Sun Mar 21, 2021 9:43 am    Post subject: Vactrol CV control Reply with quote  Mark this post and the followings unread
Hi there, I've built a distortion module but now I would like to add a vactrol in order to add a cv control to the drive pot.
I was thinking to use the simple solution that Eddy Bergmann used in the attached stripboard layout.
However I've read somewhere that vactols are not working well if connected to pots that have a big resistance. Being my drive pot an A1M I was wondering if this solution can be applied in my case. What do you think?
If not could you please suggest me another easy to build option?
 Filesize:  397.08 KB
 Viewed:  568 Time(s)
Audio files: 730
PostPosted: Wed Mar 24, 2021 12:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
the problem you migth run intro with a vactrol is the response. With no light the LDR might be in the Mohm range
but even with just a little light it can quickly go into the Kohm range. You could still try it maybe you like the result.
The Golden Shrimp Guild
lilpaula87
PostPosted: Thu Mar 25, 2021 4:22 am    Post subject: Reply with quote  Mark this post and the followings unread
I will do. Thanks a lot!
