click on image to sign up
The Garden
Page 20 of 37 [925 Posts]
Goto page: Previous 1, 2, 3, ..., 18, 19, 20, 21, 22, ..., 35, 36, 37 Next
Audio files: 730
PostPosted: Sat Apr 22, 2023 12:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
We didn't get the warm weather that was initially predicted but it did get a little bit warmer.
The tiger lillies seem to be enjoying the weather. I don't know how many of these are going to result in flowers but it's
looking very promising at the moment.
Not much happening yet with the lily and other bulbs I recently got. One of them is poking through the soil but they will
first have to grow some new roots and get established. I expect that within 2 or 3 weeks there will be some growth visible.
The henbane is starting to get larger leaves. Not sure why the plant in the center isn't doing much. It does have a little
bit of fresh growth but I am not sure if it will make it.
The climbing nightshade is also starting to wake up now.
The mandrake dropped its 2 leaves again. No idea if it will grow new leaves or decided to go dormant or just gave up.
However, there is hope. I had 3 more seeds left which I planted in February and 2 of those have now sprouted. Razz
 Filesize:  226.65 KB
 Viewed:  164 Time(s)
 Filesize:  298.31 KB
 Viewed:  138 Time(s)
 Filesize:  351.91 KB
 Viewed:  162 Time(s)
 Filesize:  252.78 KB
 Viewed:  153 Time(s)
 Filesize:  254.69 KB
 Viewed:  162 Time(s)
The Golden Shrimp Guild
Audio files: 730
PostPosted: Sat Apr 22, 2023 1:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
Some more seeds are germinating.
I picked 6 seeds of the sunflower I grew last year and all of those sprouted. I don't know what's up with the 3 leaves
but since I can only really place one of them (maybe two), that's probably going to be the one (if it survives).
There wasn't actually any need to sow them as I have been picking them out of pots constantly for the past couple of weeks
but I like the idea of growing plants from seeds that I have harvested myself. I guess it makes a bit more DIY Wink.
I also had some seeds left of the Phacelia tanacetifolia I grew in 2019. Because the bees always seems to appreciate it
I decided to try if they are still viable, by the looks of it they definitely are. They will have to make room for some other
plants later but they usually are done flowering fairly early anyway. I did sow them a bit late but everything seems to be
about a month behind compared to last year.
Lamiastrum is showing some fresh growth. Last year it didn't get to a flowering stage as the pigeons kept trampling on it.
They can't get to it anymore now so hopefully it'll get bigger again. I am glad to see it's at least still alive.
 Filesize:  305.05 KB
 Viewed:  155 Time(s)
tri-cotyledon sunflower sprout
 Filesize:  145.31 KB
 Viewed:  147 Time(s)
 Filesize:  401.25 KB
 Viewed:  179 Time(s)
 Filesize:  365.89 KB
 Viewed:  156 Time(s)
 Filesize:  227.7 KB
 Viewed:  156 Time(s)
Audio files: 730
PostPosted: Wed Apr 26, 2023 12:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
The temperature is going in the wrong direction but it should be going back up a bit soon.
Luckily the sun provides a bit of extra heat later in the day especially in the greenhouse and some things are happening.
The seeds of the white Cosmos are starting to germinate. The way I sowed them is probably not ideal.
I just laid them flat on the surface and covered them with some soil because I wasn't sure from which
side they would sprout. They'd probably do better if I stuck them upright in in the ground.
I did take a (very blurry) photo of one with its seed cap still on so now I know for next time.
The seeds of the white Snapdragons have also germinated, resulting in a lot of really tiny seedlings.
It's quite a challenge to keep them alive when they are this small.
(for reference, the name tag in the background is about 13mm in diameter)
Also still growing in the greenhouse are the foxgloves. All of them are still alive and are starting to pick up speed.
They do attract quite a lot of aphids at the moment but it doesn't really seem to be holding them back (yet).
apparently bots are interested in plants too as this thread has now had >200K views
 Filesize:  224.07 KB
 Viewed:  164 Time(s)
seed orientation reference for next time
 Filesize:  240.19 KB
 Viewed:  159 Time(s)
snapdragons
 Filesize:  332.11 KB
 Viewed:  153 Time(s)
foxgloves
 Filesize:  274.45 KB
 Viewed:  157 Time(s)
Audio files: 730
PostPosted: Wed Apr 26, 2023 1:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
More of the cheap bulbs are starting to make an appearance.
The Dahlia, which wasn't showing any signs of life yet 2 weeks ago, has now clearly awoken.
There is more growth in the pot with the Sparaxis tricolor + Allium moly. It might be some of both but they look very much alike.
There is also more growth in the pot with the Liatris spicata blue + Allium moly. I am positive the brushy looking stuff is the Liatris spicata,
but now there appears to be some of the Allium growing as well.
These bulbs are now definitely doing better than expected Shocked
The Hosta that survived is now also starting to stretch a bit more above the surface.
 Filesize:  391.13 KB
 Viewed:  160 Time(s)
 Filesize:  366.52 KB
 Viewed:  153 Time(s)
the small seedlings in there are mostly Daturas
 Filesize:  429.75 KB
 Viewed:  157 Time(s)
 Filesize:  392.93 KB
 Viewed:  154 Time(s)
Audio files: 730
PostPosted: Wed Apr 26, 2023 2:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
The strawberries seem to be doing well and they all have some fresh growth.
Saxifraga is now covered in lovely flowers. flower
I am definitely a fan and will keep my eye out for different varieties.
It is supposed to go in the planters with the other alpine plants or at least what's left of those.
They definitely don't look like this anymore. There is still some stuff going on, some alpine plants and some weeds.
plantfinder
Usually when I want to find the name of a plant I use google to find images with search terms describing its appearance.
I might not always find directly what I am looking for but it points me in the right direction and most of the time I am able to
identify it after a couple of searches.
This time I tried something different. I had seen apps for smartphones that can identify plants but I was curious if there wasn't
one that I could just use in my browser (I don't use a smartphone). This lead me to https://identify.plantnet.org/ which works
remarkably well.
The first one got identified as Cymbalaria muralis and is more of a weed. Not that I don't like it and it has made an appearance
in other pots, but I don't want it in there.
The other one is one of the alpine plants that is actually thriving and overtaking the container. Wouldn't have been that hard
to find out but got identified as Sedum rupestre. At least that's mostly likely what it is. There is also still a substantial amount
of Sempervivum but that's being smothered by the Sedum.
Now that the crows have a new feeder they don't need the planters anymore to stand on so I can empty them out and see
what else is growing in there (at least a dandelion, geranium and some grassy stuff). Then transplant what I want to keep
and get a couple of new plants.
 Filesize:  341.82 KB
 Viewed:  158 Time(s)
 Filesize:  225.88 KB
 Viewed:  154 Time(s)
 Filesize:  265.81 KB
 Viewed:  159 Time(s)
 Filesize:  322.55 KB
 Viewed:  159 Time(s)
 Filesize:  413.45 KB
 Viewed:  166 Time(s)
Former site admin
Audio files: 353
PostPosted: Wed Apr 26, 2023 3:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
[...]one that I could just use in my browser (I don't use a smartphone). This lead me to https://identify.plantnet.org/ which works
remarkably well.
I did not know it as a web page - I'm having it as an app on the phone .. and most often the flora (heukels) agrees with it when i do a 'make sure' search there, so the app works very well nad the page probably uses the same algorithm .. and .. a picture is a lot easier indeed than counting petals, judging leaf shapes ... and stuff Exclamation
And yes .. it is pretty cold .. but eh .. we did not have IJsheligen (Ice Saints, May 10 or so) yet .. so some frost can be expected .. and besides .. since we have kings day here on April 27 it is on average about 4C colder than queens day was (April 30) ... which makes no meteorological sense Shocked
Still, your paradise seems to do very well Cool
View user's profile
Audio files: 730
PostPosted: Fri Apr 28, 2023 12:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
well, ijsheiligen is about as scientific as "April doet wat hij wil" and "in Mei leggen alle volgels een ei".
It usually works out though and the start of May is generally when I know things will really start to grow and it's unlikely to get frost.
It's not so bad on my balcony anyway, it's shielded from the elements and not at ground level so temperatures don't drop as much
if it's only cold at night.
was not familiar with Heukels' Flora btw.
Audio files: 730
PostPosted: Fri Apr 28, 2023 1:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
quick update on the peppers.
They are still doing great and I tried to make a group photo. It was a bit tricky but I managed to set them up in the hallway.
I did top the 'blondy'* plants earlier this week (after the photos) because they were getting too long and leggy. I don't think it
has anything to do with lack of light, just the type of pepper. I usually don't like to top peppers as it sets them back a bit and
the growing season here isn't that long to begin with.
6 pepper plants found a new home today.
*they are labeled as blondy on the site I got the seeds from but i think it should actually be blondie.
This is a mix of the least tall ones: Fatalii, 7pot Lucy, Bhut jolokia Strain II, Dwarf Chiltepin
 Filesize:  310.32 KB
 Viewed:  151 Time(s)
all together now
 Filesize:  327.56 KB
 Viewed:  152 Time(s)
blondy plants in the back towering over everything else
 Filesize:  245.93 KB
 Viewed:  154 Time(s)
Former site admin
Audio files: 353
PostPosted: Fri Apr 28, 2023 2:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
Sure .. it is old "farmer's wisom" (lately they are showing not to be /that/ wise though Shocked ) .. meanwhile, to throw a tad of science in .. while temps on average are going up .. oddly enough there seems to be more late frost in the early growth season in the Netherlands :: (in dutch) https://www.knmi.nl/over-het-knmi/nieuws/groeiseizoen-kent-steeds-langer-nachtvorst
The grass was white here btw .. this morning .. or was that yesterday .. hmm .. but it was white Laughing looks like that went well for you though Cool
View user's profile
Audio files: 730
PostPosted: Sat Apr 29, 2023 12:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
I cleared out one of the alpine planters (seems to make sense to call 'em that) and used Pl@ntNet to help identify some things.
Now I know that the stuff I always had to pull out is chickweed (Cerastium glomeratum).
I am not entirely sure if the Erigeron is identified correctly. Pl@ntNet came up with a couple of similar looking plants and I picked what I think
it most likely is. There was also some Ivy-leaved Toadflax (Cymbalaria muralis) growing out of the bottom of the container.
And of course a Dandelion (Taraxacum officinale) and herb-Robert (Geranium robertianum).
 Filesize:  391.1 KB
 Viewed:  133 Time(s)
macro shot
 Filesize:  197.31 KB
 Viewed:  138 Time(s)
another macro shot. There are still bits of sedum left but they are very tiny.
 Filesize:  267.76 KB
 Viewed:  145 Time(s)
 Filesize:  196.51 KB
 Viewed:  137 Time(s)
Audio files: 730
PostPosted: Sat Apr 29, 2023 12:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
more photos
Chickweed
 Filesize:  174.26 KB
 Viewed:  143 Time(s)
also Chickweed
 Filesize:  200.23 KB
 Viewed:  133 Time(s)
not so sure about this one.
Could just be a Daisy (Bellis perennis) but I think they have wider rounder leaves.
The bottom leaves look like it though.
 Filesize:  295.52 KB
 Viewed:  158 Time(s)
herb-Robert
 Filesize:  238.55 KB
 Viewed:  134 Time(s)
Audio files: 730
PostPosted: Sat Apr 29, 2023 12:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
The Dandelion still had 5 unopened flower buds and because it's loved by bees I put it in a pot. I filled the remaining space with some of
the other plants I removed so now I have a pot of weeds.
I planted the Cymbalaria muralis in a different container that will get some climbing plants in it later. Probably some morning glories
or maybe a Passiflora incarnata if those seeds sprout.
 Filesize:  385.14 KB
 Viewed:  139 Time(s)
another Dandelion flower already opened
 Filesize:  315.41 KB
 Viewed:  142 Time(s)
 Filesize:  440.02 KB
 Viewed:  141 Time(s)
Audio files: 730
PostPosted: Sat Apr 29, 2023 1:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
The other alpine planter didn't have much weeds in it. Mostly just some Sempervivum and Sedum rupestre.
I didn't clear it out yet, only removed some of the Sedum that was covering the Sempervivum.
I made cuttings of it which I placed in wet perlite as an experiment. It should be easy to propagate through cuttings
but I don't know if it will work well in perlite.
There were some bits of Sedum tetractinum (?) in it which I temporarily placed in a separate pot.
I also found Borage (Borago pygmaea) in there. Apparently it's liked by bees so I placed it in a small pot for now
and then I'll try to find a spot for it once it's a bit larger.
 Filesize:  402.16 KB
 Viewed:  141 Time(s)
 Filesize:  271.25 KB
 Viewed:  161 Time(s)
Borage
 Filesize:  225.53 KB
 Viewed:  143 Time(s)
 Filesize:  149.63 KB
 Viewed:  139 Time(s)
 Filesize:  304.22 KB
 Viewed:  147 Time(s)
Audio files: 730
PostPosted: Sat Apr 29, 2023 1:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
I took a trip to the garden center yesterday to look for alpine plants and petunias and/or marigolds for the container with the strawberries.
I guess it's too early for alpine plants as they only had some in large pots that are too big and expensive. They usually have a
much wider assortment in small pots that are a lot cheaper so I guess i have to wait a bit longer.
I did get some Marigolds, a Petunia and a mix of Calibrachoa aka million bells which are basically mini petunias. I had some of those
last year and I can understand why they are called million bells.
I also got some more bulbs Embarassed They were all on sale and I found a package with 50! small Iris hollandica bulbs for €2,- which look
very alive and ready to grow. They don't get very large and should flower in the next month or so (probably more like 2 on my balcony)
so I want to plant those in the large planters in which I also planted the Lily and Dahlia bulbs. According to the packaging they should
actually be planted in autumn but it's a bit too late for that. It is possible that they just won't flower this year.
I like the font they used for this.
 Filesize:  220.01 KB
 Viewed:  152 Time(s)
 Filesize:  221.21 KB
 Viewed:  141 Time(s)
 Filesize:  240.14 KB
 Viewed:  149 Time(s)
 Filesize:  202.58 KB
 Viewed:  139 Time(s)
Audio files: 730
PostPosted: Sat Apr 29, 2023 2:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
Marigolds, Petunia and Million bells have been planted. It's nice to have some more color on my balcony now.
Petunia and Calibrachoa living together! Mass hysteria!
 Filesize:  226.91 KB
 Viewed:  138 Time(s)
 Filesize:  334.63 KB
 Viewed:  140 Time(s)
 Filesize:  304.29 KB
 Viewed:  142 Time(s)
Audio files: 730
PostPosted: Sun Apr 30, 2023 2:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
Planted some Irises today, repotted some plants, sown some seeds and did a bit of overall maintenance.
It's slowly starting to come together and in a couple of weeks from now it will probably be a lot greener.
Might remove the greenhouse next week depending on how the weather forecasts will be.
I spotted a couple of bees that were looking for nesting space of which there is plenty,
didn't expect to still see more of them at this time.
Also came across a ladybug which I placed on the foxgloves to help with aphid control.
seed nursery on the top shelf of the greenhouse
 Filesize:  297.88 KB
 Viewed:  131 Time(s)
view from inside
 Filesize:  327.8 KB
 Viewed:  132 Time(s)
 Filesize:  196.44 KB
 Viewed:  135 Time(s)
Audio files: 730
PostPosted: Fri May 05, 2023 11:58 am    Post subject: Reply with quote  Mark this post and the followings unread
ladybug is still patrolling the foxgloves Cool
Hanging basket with Petunia and Calibrachoa is celebrating the sun with more flowers.
The Hosta is slowly starting to uncurl its leaves.
The bees have been buzzy on my balcony all week. There aren't many yet this year but now there should be more next year.
They seem to prefer the paper tubes over the drilled blocks of wood.
I posted a couple hours of footage here https://youtu.be/Y4GlIPAVxKo, it's not that exciting though.
 Filesize:  285.65 KB
 Viewed:  140 Time(s)
 Filesize:  310.51 KB
 Viewed:  139 Time(s)
 Filesize:  194.06 KB
 Viewed:  135 Time(s)
 Filesize:  255.72 KB
 Viewed:  140 Time(s)
Audio files: 730
PostPosted: Fri May 05, 2023 12:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
some more seedlings have popped up. Only one Leonotis leonurus so far but if I can keep it alive that's enough.
 Filesize:  176.12 KB
 Viewed:  129 Time(s)
 Filesize:  297.43 KB
 Viewed:  131 Time(s)
 Filesize:  300.18 KB
 Viewed:  141 Time(s)
 Filesize:  284 KB
 Viewed:  143 Time(s)
Audio files: 730
PostPosted: Tue May 09, 2023 11:34 am    Post subject: Reply with quote  Mark this post and the followings unread
I had a bit of a busy weekend as it was finally time to transplant the peppers and place them outside.
For this the greenhouse had to go and I could start trying to figure out how to place things which is always a bit of puzzle.
With the greenhouse removed I got better access to the planters with the lily and dahlia bulbs so I took some photos
of those. There wasn't much happening in there anyway apart from 1 lily which already started growing fairly shortly
after it was planted (can you recognize it on the photos ?). The other lilies have now also started to breach the surface,
I believe there should be 10bulbs in there in total but I don't see all of them yet.
Three of the five Nerines are showing some growth, I am curious if the other two will follow later or will not grow at all.
The bulbs looked alright.
Two of the three Dahlias have some new growth on them, the other one is in another pot but doesn't appear to do much yet.
That one was also damaged a bit but it might still do ok.
The Dahlia "Red Skin II" found a nice spot next to the strawberries. It will probably be moved later depending on its size.
The small bulbs on both sides are Irises
 Filesize:  409.92 KB
 Viewed:  144 Time(s)
 Filesize:  364.17 KB
 Viewed:  151 Time(s)
 Filesize:  299.74 KB
 Viewed:  146 Time(s)
 Filesize:  340.54 KB
 Viewed:  132 Time(s)
 Filesize:  352.91 KB
 Viewed:  136 Time(s)
Audio files: 730
PostPosted: Tue May 09, 2023 12:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
I noticed something had been snacking on the hazel. I initially couldn't find it but when I returned later and checked under
all the leaves again I found a small green caterpillar. I think I might be from a winter moth.
 Filesize:  185.6 KB
 Viewed:  136 Time(s)
 Filesize:  109.82 KB
 Viewed:  125 Time(s)
Audio files: 730
PostPosted: Tue May 09, 2023 12:32 pm    Post subject: Reply with quote  Mark this post and the followings unread
I've sown some buckwheat seeds on April 30th and as expected they started to germinate shortly thereafter.
Once the plants have some true leaves I'll have to thin them out a bit.
If you want something that is easy to grow from seed, grows quickly and attracts bees and other pollinators,
then buckwheat is not a bad choice. thumright
Catnip is looking very healthy at the moment. I'll probably cut it back a bit again to get more side growth.
The Phacelia is getting larger and there are now some Daturas coming up in the same container as well.
There is also one other seedling that has been there for a bit longer that I don't recognize yet.
buckwheat, it's already looking larger today.
 Filesize:  403.79 KB
 Viewed:  140 Time(s)
 Filesize:  317.54 KB
 Viewed:  143 Time(s)
 Filesize:  429.08 KB
 Viewed:  145 Time(s)
Audio files: 730
PostPosted: Tue May 09, 2023 12:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
Lungwort is still flowering which gets attention from bees. I don't think the mason bees are interested in it which are still buzzy.
Lily of the valley is now also flowering with its pretty white bells.
and to close off this trio of flowering plants there is a close up shot of the ivy-leaved toadflax.
 Filesize:  294.94 KB
 Viewed:  148 Time(s)
 Filesize:  164.32 KB
 Viewed:  135 Time(s)
 Filesize:  151.06 KB
 Viewed:  132 Time(s)
Audio files: 730
PostPosted: Tue May 09, 2023 1:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
Some photos of how it looks now though it doesn't show everything on the left side. I am using an old aquarium tipped
on its side for seed germination, on top of that I have 2 pots with 3 pepper plants each and next to it is another pot
that has 3 pepper plants. That's 21 pepper plants placed so far (I still have more inside).
the orange pot that's visible in the lower left corner has been replaced with a pot with 3 more pepper plants
 Filesize:  339.88 KB
 Viewed:  143 Time(s)
Still catches me by surprise every year how fast it grows.
 Filesize:  326.16 KB
 Viewed:  142 Time(s)
(the foxgloves have been planted now)
 Filesize:  343.5 KB
 Viewed:  148 Time(s)
Trying to group some of the different poisonous nightshades together
Hyoscyamus albus 'henbane' 3rd year now for these "annual" plants
Atropa belladonna var. lutea 'deadly nightshade' (just out of view in this photo but visible on the next one)
 Filesize:  371.03 KB
 Viewed:  135 Time(s)
 Filesize:  343.6 KB
 Viewed:  149 Time(s)
Audio files: 730
PostPosted: Tue May 09, 2023 1:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
I also had a bit of fun with the crows on sunday.
Audio files: 730
PostPosted: Wed May 17, 2023 7:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
I took a trip to the garden center yesterday to look for alpine plants .. I guess I have to wait a bit longer.
Instead of waiting I decided to have a look online instead to see if I could find anything and I did.
As usual I got a bit carried away (plants are cheap, shipping isn't) and ended up ordering 7 different
Sempervivums, 5 different sedums and 1 delosperma.
Because the tracking site wasn't properly updated the plants were boxed up for 4~5 days before I got them, thanks DPD Confused .
I wasn't really worried about the plants but I did not expect that the sempervivums would open up so much so quickly,
though it is possible they were already like that before shipping. I was hoping they would close up again after a couple
of days but there doesn't seem to be much change. Of course any offshoots will be fine but it kinda sucks for now.
The idea was to place all these plants in the same 2 planters that I had the sedums and sempervivums in before, but because the
sempervivums are rather globular (and a bit larger than I was expecting, which is not a bad thing) they don't fit in there very
well without getting too crowded. To be honest I also don't really like those planters, or at least not the way they are mounted
to the railing. They also hang rather low and the new large planter (strawberries + marigolds) now blocks them from my view.
So that got me thinking about some alternatives which resulted in a weekend project.
While trying to figure out what options I had I somehow got the idea of placing the plants on top of the railing for which I would need
a very shallow planter, something like,... a gutter!
I looked online to get an idea what was available at he hardware store and I had 3 size options. The largest one wasn't really useful
and I was thinking about the middle sized one but once I was at the hardware store it became clear that the smaller size would be the
better option. The main reason being that the middle sized one was too wide to place on top and because of its rounded shape it was
actually very shallow and wouldn't even be able to fit many of the plants. (and it's a very difficult shape to plant in).
I also had the choice between grey or brown. Normally I'd pick brown but in this case I went with grey which I thought would blend in
better with the grey railing of my balcony and make the plants the main focus. I also got some grey gravel to go with it.
Of course if the middle sized one wouldn't be able to fit many plants then surely the small one wouldn't be either.
The solution for that problem was to simply get plants that do fit I actually did wanted some more delosperma anyway
and while I was looking on the website for gutters I had already noticed that they happen to have a set of 6 available, so I got those.
For mounting the gutter onto the railing I got the available brackets but cut off the part that is normally used to mount them to a roof/wall.
I then drilled a hole in them so they could be screwed onto the already existing brackets for the large planter. To prepare the gutter
for planting I glued end-caps on either side and drilled holes along the bottom for drainage (6mm with 5cm spacing). These holes
were covered with a strip of mesh cut from a bug screen which in turn got covered with a layer of gravel. I did all the planting inside
which made mounting it a bit of a challenge but it all went smoothly (I was afraid I might tip the whole thing over the railing).
I am very pleased with how it turned out even though it didn't solve my initial problem. I was able to put some of the sempervivum
in it but still need to find a solution for the rest. I do have some ideas but I'll have to think about it a bit more so that might be something
for next year. For now I transplanted them in slightly larger pots and placed those in one of the 'old' planters so that they at least can get
enough light. The sedum is a bit smaller and I was already able to place a couple of those around in pots.
 Filesize:  373.5 KB
 Viewed:  149 Time(s)
holes
 Filesize:  182.3 KB
 Viewed:  135 Time(s)
this is what the gutter is screwed on to (2x)
 Filesize:  188.97 KB
 Viewed:  144 Time(s)
 Filesize:  255.21 KB
 Viewed:  133 Time(s)
After washing some of the gravel I put it in pots so it could dry
 Filesize:  268.12 KB
 Viewed:  140 Time(s)
