Microgranny
Page 1 of 1 [2 Posts]
Estebandito
PostPosted: Sat Jul 22, 2023 2:33 am    Post subject: Microgranny
Subject description: does MG self-sabotage when playing for extended periods of time?
Microgranny owners I was wondering if you have experienced issues with MG when it play continuously for extended periods of time. I recently used my MG as part of a sound installation, continuously playing a garbled sample with random shift mode switched on. the installation is on a timer but since I can’t automate MG to play on power on, I have it on a seperate power supply, which doesn’t switch off. So MG is running 24/7. I went into the exhibition the other day and found MG still running, but there was no output, and no samples would load after manually resetting the device. I have noticed the deterioration of samples -of the actual wav files- after intensely messing with them before. Even after deleting the accompanying txt files on the micro SD card. Has anyone here experienced something similar? Is there a solution?
thanks!
 Filesize:  1.93 MB
 Viewed:  358 Time(s)
Audio files: 267
PostPosted: Fri Jul 28, 2023 10:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
Sorry, I don't know anything about the MG, but I like the look of your installation.
