Posted: Wed Feb 21, 2024 2:28 pm Post subject:
Gyrator bandpass filter Subject description: Almost an octave filter
Seeing videos about old test equipment (Hainbach and others), I wanted to make a bandpass filter. The passive old ones use coils, which I don't want, so I looked for schematics of newer designs. I found an article by Rod Elliott (ESP):
https://sound-au.com/articles/gyrator-filters.htm
Instead of making an EQ as he suggests, I just wanted to pass one band at a time,
such as in this video:
https://www.youtube.com/watch?v=XNQ4ULNwi7g which demonstrates an octave filter (at 7.00 onwards).
I came up with the circuit in the schematics below; I had a switch with 6 positions and two poles, hence the 6 frequency bands.
The opamp is powered by one 12 volt supply, but if you have a dual supply just connect all the "6 V" points to ground (not U1D pin 14; just disconnect this output from the circuit).
R6 determines the Q factor of the filter - experiment with other values if you want. Higher resistance increases the Q, but also lowers the output - compensate by increasing the value of R8.
The capacitors determine the center frequencies. Higher capacitor values give lower frequencies and vice versa.
One idea would be to use a couple of CD4051B multiplexers to switch the capacitors, then you could have 8 bands, but they would need to be controlled in some way, and the complexity rises quickly.
It could be made into a synth module, but I only made it in a standalone box. I find it easier to use then. My switch was a little hard to turn, but with a big enough knob it's ok.
I made some calculations and measurements on the circuit:
Posted: Fri Feb 23, 2024 12:51 pm Post subject:
Gyrator bandpass filter Subject description: Image and sounds
Here is an image of my unit; I used the box of an old router or something. Also a couple of sound examples with white noise. There is considerable switching noise, but that just adds to the character, I think. (I also updated the schematics; the new version is exactly the same, just removed som elements outside the page.)
Helge
noisetest1.mp3
Slow switching
Filesize:
421.03 KB
Duration:
0:23
Viewed:
1080 Time(s)
noisetest3.mp3
Rapid switching
Filesize:
296.44 KB
Duration:
0:15
Viewed:
1068 Time(s)
Filesize:
255.51 KB
Viewed:
265 Time(s)
thanks for sharing this ,this is exactly what i needed ,as i was looking at some passive filters from 9th issue of electronotes and those all need that expensive coil of 500 mhy ,i built the SIAM (Siemens inspired EQ) that also has 8 gyrators and it makes nice sinewave in feedback _________________ http://synthacks.blogspot.com/ шематикс
