furio
Posted: Wed Oct 09, 2024 6:06 am Post subject:
Hardware Strategies Systems |
Best summary found online:
"Since a digital transport is always located before a DAC in the signal chain, the sound of a DAC can only be as good as the digital transport is.
Let us be clear about one thing in high performance audio: There are no unimportant or negligible aspects- everything matters when it comes to maximum sound quality! Maximizing the sound quality of an audio system is a cumulative process , it becomes more than significant. That philosophy also applies to computer and music servers, even if they are galvanically isolated from the USB converters and DACs. There is a reason as why computer based audio sounds less appealing than some high performance CD transports and integrated CD players. The main reason behind that is usually maximum compatibility (that comes with additional hardware and software complexity) comes at cost of maximum performance, reducing software and hardware to a necessary minimum. In a way, approaching the simplicity of a CD transport/player is desirable. For a number of reasons, the quality of power supplies and interconnections for the computers and music servers is a very neglected aspect. Once those quality issues are addressed, the music servers cannot sound inferior in any way to anything." (1)
* Hardware Strategies System with HiFi Digital Transport via USB with Seasonic TX-1000 audio grade PSU under construction (Hi End Compact Miditower loaded max 10% for low noise ripple hybrid mode). 10TB system & data backup ~230 MB/sec + 20TB OS & data: RAID0 ~450 MB/SEC... so 30TB total for two or more 24/7 OS for Hi End Mastering
* with STANDARD HiFi Digital Transport via RME HDSP (not USB) with Corsair AX1600i military grade PSU under construction (Hi End Tower loaded max 7% for low noise ripple hybrid mode). 20TB OS & data: RAID0 ~450 MB/SEC... for one or more 24/7 OS for Hi End RIP & Mastering
* Both machines perform extreme cybersecurity with many years of reverse engineering and microcode patching for CPU
Both setups require between 40-100W and the older machine with DDR3 RAM is much more responsive. Really like a real-time musical instrument. However DIVA runs at 768kHz in real-time only with 50% of the patches. The newer 7 year old CPU runs with all patches at 768kHz with DIVA and ACE on Harrison Mixbus. Bitwig Studio is limited to 192kHz. (2)
So both systems can run as streaming servers with a consumption below 40W and very low temperatures 24/7.
Currently installed to maximize the focus of the streams:
.SATA Filter to obscure HDD noise
.RAM Filter to reduce the CPU background noise
.BUS Filter to improve the CLOCK focus
.FAN Filter for reducing System Noise
More filters need to be ordered to complete the job at the moment 40-50 hours for both. (3)
A high quality Power Conditioner must be combined to reduce high frequency noise and maximize the stream focus.
Eurorack panel as RAID base. All unnecessary plastic and cables have been removed to reduce operator poisoning with flame retardant. Externally the removed plastic filters will be replaced with aluminum grids.
We are thinking about making NANO-Traps and would be welcome advice on choosing safe electromedical grade silicone to cover as much as possible and block environmental chemical pollution from cables and connectors.
Hi Perfomance Sustainable PCs built to preserve the health of people, animals and plants. So we get a full electromedical orientation 4 chemistry and electronics music.
*** Technology research conducted by Multiple Chemical Sensitivity patient with the help of extreme inflammation as a sensor. Corsair power supply stinks too much and is not recommended for patients with autoimmune syndromes. We have found fans on the market that are completely odorless, so the chemistry should be soft and safe. When plastic stinks, the chemistry is stiff and dangerous to health. These machines can handle (for a reasonably short period of time) Patients with Chronic Fatigue Syndrome, Fibromyalgia, Multiple Chemical Sensitivity, Electrosensitive and so on... For continuous daily use the system must be placed in a separate room from the operator. Obviously also separate air ventilation. By drilling the wall you could bring cables only for keyboard, mouse and video monitor and passive audio monitor for minimum pollution in the operating desk room. Computers, converters, pre, amplifier must operate in the server room separated from people for health safety.[/i]
.1 Real Time Kernel Quality, Operating System Settings and Liquid Lightness of WM like iceWm or more minimal, Renderer (player) perfection... are the starting point on which to develop a state of the art transport with ASMEDIA 10 or 20 GB/sec PCIe USB Host or PCI/PCIe DSP Card with Standard Protocols. It is the source that is the fundamental point of the whole chain. After comes the quality of the receiver, isolators and receiving transport power supplies, colck/reclock, DAC and output stage. When the output stage is passive purity or zero feedback, micro/nano detail and focus will be extreme. To learn to listen everyone can start from the Real Time Kernel.
2. This only with Cadence and old streaming libraries via AMD 65W TPD CPU. This for example works with AVLinux 2021, realesed in 2022 and updated to 2023. So for about a month in January and then hidden because the only UAC2 compatible version and immediately deleted and replaced in non-functional (AVLinux maintainer can only be poorly capable in understanding audio quality or a corrupted because the only working version for playback and mastering of the last 10 years). Cloneable OS on request. A high sampling rate is essential to get a decent sound with virtual synths. With modern operating systems since '23 we can no longer install Cadence for JACK. Avoid current AVLinux because it sounds terrible and those who still use Ubuntu should scrap it immediately because it doubles the latency. So with a new installation of debian, arch and so on we are limited to 192 kHz with DIVA and ACE in Real Time. However these old machines have a Real Time frequency of 1000Hz. With the new 4nm technology CPUs the AVX512 vector streaming protocol is present and the RT Kernel can be compiled and so it is possible to compile a Liquorix Custom Kernel with a frequency of 2000Hz to verify the functioning of DIVA at 384-768kHz in Divine Mode. AMD is preferable because with the best motherboards it is better balanced than intel and works with half latency audio. Double RT performance with the best Debian and MX distros or our Supersonic Seduction (based on antix).
.3 It has been dismantled, moved and reassembled several times. It is however difficult to be able to customize the machine in just 10 hours without having already tested the setup and already chosen the materials or special pre-built pieces. These two new tested cases cost little but can waste a lot of time. Just for the material of the latest updates it cost over 2K with minimum 100 hours of order management for the choice of accessories to test. Maybe it's already 2K5 (just ordered two more BUS-Filters to better isolate the PCIe asynchronous transport clock and because the old PCI card is good to enhance RME's revolutionary Stady Clock technology) but there are still two new HDDs for spare or for other new machines. Absolutely avoid non-volatile memories because they destroy the stream, causing frequency response distortion and a supersonic black hole in the crossover.
It seems that most users can't "hear" the supersonic frequencies but SSD vibrates a black hole in the monitors. Avoid SSD risk and... record/listen only 96 kHz and multiples to be equipped with vibrational grip and maintain energy and consciousness personally.
| Description: |
| AX1600i RME HDSP Digital Transport |
| Filesize: |
4.97 MB |
| Viewed: |
273 Time(s) |
| Description: |
| TX-100 USB Digital Transport |
| Filesize: |
3.82 MB |
| Viewed: |
291 Time(s) |
| Description: |
| Sustainable Cyberpunk Monitor 99% poison reduction 1/3 |
| Filesize: |
3.56 MB |
| Viewed: |
255 Time(s) |
| Description: |
| Sustainable Cyberpunk Monitor 99% poison reduction 2/3 |
| Filesize: |
2.87 MB |
| Viewed: |
276 Time(s) |
| Description: |
| Sustainable Cyberpunk Monitor 99% poison reduction 3/3 |
| Filesize: |
3.14 MB |
| Viewed: |
231 Time(s) |
_________________ 100 MHz Transients Resolution Conscience ~ Modular Synth Guru ~ Digital Transport Architect ~ digitaltransport.org |
furio
Posted: Sat Oct 19, 2024 12:49 am Post subject:
The all aluminum compact system with Seasonic TX-1000 power supply is almost ready. We have never seen anyone else use a Common Reaction Filter to reduce HDD noise. We are waiting for the new BUS Filters to better isolate the clock of the ASMedia ASM3242 Asynchronous Digital Transport. To maximize performance we use Furman AC-210A-E Video Power Conditioner and 5KW USB Cable Isolator by HiFiME. To maximize the streaming focus of the XMOS USB Receiver. With subsequent double optical isolator before and after the FIFO Reclocker 7+7KW by JLSounds.com (the two DSPs of transport and reclock should also give some isolation above the KW each... so ~20KW for PC ground separation in total).
Both fans push air in and follow CPU temperature. For desktop office use including firefox with online image viewing max temp 23 degrees centigrade. All 12 threads at 100% as Kernel compilation under 50 degrees. This with minimum rotation speed/ambient noise.
| Description: |
| Filesize: |
3.77 MB |
| Viewed: |
276 Time(s) |
| Description: |
| Filesize: |
4.4 MB |
| Viewed: |
279 Time(s) |
| Description: |
| Filesize: |
4.09 MB |
| Viewed: |
274 Time(s) |
| Description: |
| Filesize: |
3.03 MB |
| Viewed: |
276 Time(s) |
| Description: |
| Filesize: |
2.77 MB |
| Viewed: |
235 Time(s) |
furio
Posted: Mon Oct 21, 2024 3:28 am Post subject:
HiFi Chrome Decouplers for Master Digital Transport
| Description: |
| Filesize: |
3 MB |
| Viewed: |
227 Time(s) |
| Description: |
| Filesize: |
2.55 MB |
| Viewed: |
245 Time(s) |
| Description: |
| Filesize: |
2.58 MB |
| Viewed: |
261 Time(s) |
| Description: |
| BUS Filter Update for Asynchronous Clock Isolation ~ Digital Transport ~ 20GB/sec USB Sandwich #Elfidelity #StarTech #ASMedia #ASM3242 |
| Filesize: |
3.55 MB |
| Viewed: |
260 Time(s) |
| Description: |
| Filesize: |
3.85 MB |
| Viewed: |
320 Time(s) |
furio
Posted: Tue Apr 14, 2026 2:08 am Post subject:
OK, we rejected the Ryzen 5 CPU and DDR4 RAM. It's a PC CPU that's too modern and fake, because it's a RISC simulating a CISC. The CPU must not have any phantom stages. The latest CPUs/Mainboards for PC and Deterministic Real Time were produced in 2011, 2012, and 2013. So even with motherboards produced in 2013-2014 at the latest, it's possible to record and play realistic audio. DDR4 RAM is too slow, and to reproduce all the supersonic transient resolution AUDIO REQUIRES the fastest possible DDR3 RAM. Since November-December 2025, we've been using that black machine with AMD 3 Physical Cores and 800 MHz RAM with 6-6-6 latency. Absurdly, the RAM set to 800 MHz is much faster even at copying files. So it would be better to get RAM with 5-5-5 latency, which is the fastest available. When RAM is too slow, transients are lost, and the sound is flat and distorted. Obviously, the user should only record and listen to 96 or 384 kHz and multiples to wake up with a state-of-the-art GNU/Linux System V audio-grade operating system.
The processor must not have an integrated graphics card because it causes thermal jitter. So it would seem that the only audiophile-grade CPUs in existence would be the AMD 6300 8W (the most expensive boxed-quality option) with three physical cores, and the Xeon V2 and V3 with four physical cores (without the final 5 in the code that integrates the graphics card). The rest are only for production with pre-listening quality, such as the gas-can MAC or Audio Hypster for idiots (including conceptually flawed 25K streamers).
The streamer in the store is wrong, it can only be built. We'll now test these popular motherboards for industrial and medical applications with Xeon V2 and V3 processors (69W and 80W nominal) using strategies such as undervolting, underclocking, and disabling Spy-486 CPUs for Audio Grade Performance (approximately 10W, 4 physical cores) on ultra-low-noise 2-3W boards.
V2 (the chipset includes a PCI bus, very useful as a stethoscope with RME HDSP) is more stable and low-noise because the RAM regulator is external. V3 (iVR-FIVR internal regulator) runs hotter and therefore produces noise on the CPU's internal ground plane and heat. V3 is more powerful, the chipset is superior, but there are slight jitter issues and there is no PCI bus.
Our Supersonic Seduction OS is still available as a demo for learning. We have a much more powerful DRT OS ready, which sounds much better. We can't put it online for public safety reasons because it's too powerful. Contact us.
REFERENCE Recording and playback must be done in RAM. Therefore, with this technology, it is physically possible to install a maximum of 2 x 8 GB = 16 GB in the system. 1 GB for the OS and 15 GB of dynamic RAMdisco.
Software and computing power are relatively unimportant. What really matters is the speed of a SystemV OS with a real CPU. MPD is globally recognized as the best renderer, and SoX is recognized as the best recorder.
| Description: |
| Intel Xeon 1230 V2 - Note: Only two DDR3 RAM SIMMs can be used, as with four, the machine is handicapped by slower RAM and loses transients. |
| Filesize: |
3.55 MB |
| Viewed: |
115 Time(s) |
| Description: |
| AMD FX Single Core nforce 3 RME Absolute Refernce & AMD FX 6300 3 Core USB/Ethernet PCIe Reference |
| Filesize: |
2.91 MB |
| Viewed: |
106 Time(s) |
| Description: |
| Isolated AKM AK4490 Low Fase Distortion NDK Reclock ~ Studio Flagship Reference - non active utra hires audiophile aoutput stage |
| Filesize: |
6.13 MB |
| Viewed: |
158 Time(s) |
| Description: |
| Isolated AD1865 is dual 18-bit R-2R 768 kHz DAC ~ Discrete Audiophile Zero Feedback Output Stage at 50 MHz opamp/transistor linear power ~ NDK DSP/FiFo Reclocker for 24-32 bit playback |
| Filesize: |
2.55 MB |
| Viewed: |
130 Time(s) |
