Looking for a replacement G1/NL3 LCD screen
Page 1 of 1 [5 Posts]
tomhall
PostPosted: Tue Aug 01, 2023 11:22 am    Post subject: Looking for a replacement G1/NL3 LCD screen Reply with quote  Mark this post and the followings unread
Does anyone have a lead on a replacement LCD for a NL3 (it’s the same as the G1 Modular)??
Even the aftermarket OLED folks are no longer advertising.
Any help would be appreciated
Thanks.
3phase
G2 patch files: 141
PostPosted: Thu Oct 24, 2024 8:08 am    Post subject: Reply with quote  Mark this post and the followings unread
Why do you want to replace them?
tomhall
PostPosted: Thu Oct 24, 2024 12:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
because they've partially stopped displaying the text correctly
3phase
G2 patch files: 141
PostPosted: Sat Oct 26, 2024 12:48 am    Post subject: Reply with quote  Mark this post and the followings unread
Oh, thats bad..
I had problems with an age dimming of the display lately and had a look inside that area.
The Display is from the form factor and soldering connection not the standard part you get at any corner.
Its solder connections are on the left side of the display, and could potentially micro break when mechanical stress hits the Display..
Re soldering the pins of the display board might help.
Good Luck
outofhand
PostPosted: Tue Apr 08, 2025 8:11 am    Post subject: Reply with quote  Mark this post and the followings unread
I am in the same boat, if anyone has any tips.
Nord Rack G1 screen has started showing random characters, while 1/3 of the screen is completely blank.
The synth still works so I am hopeful an LCD screen replacement is all that's needed.
