Coming up on Radio 1 at
Build Pictures 2025
Page 3 of 3 [65 Posts]
Goto page: Previous 1, 2, 3
analogmonster
PostPosted: Sun Aug 24, 2025 3:05 am    Post subject: 8 CV to MIDI converters
Subject description: CV Option / expander module
Hello everyone,
I developed a module to expand my 8 channel CV2MIDI - Converter in direction towards a kind of real fun "Modular Sequencer":
It consists of 8 independent channels controlled by 8 "control cells" on the right side.
The module is pure analog with 4 PCBs hosting 2 channels each:
Posted Image
(Above: Please note my "sustainable" (to abuse the bad word of this decade) PCB approach by using very old and used vintage resistors with clear-text resistor values coming from the pre-color-code and pre-pcb times (in fact they propably served in Adolf's table-top radios during the "Third Reich" ๐Ÿ˜‚๐Ÿ˜‚๐Ÿ˜‚) and found their way to me when I bought an electronic convolute from the heritage of a dead electronic nerd on ebay...)
Anyway, this module offers a variety of new sequencer modes when used in conjunction with my 8 channel CV2MIDI Converter:
Posted Image
The module provides 8 CV sources and 8 clock sources (CLK), which are adjusted by corresponding control pots.
The clock behavior is controlled by cells on the right module side.
Witch each controller cell you set the clock operation for the corresponding channel / step.
Switching it to "ON" means a permanent 5V output at the clock output jack.
Switching to "CLK" means a normal clock operation.
Both are indicated with corresponding LEDs.
For working with the CVOption module a new program was developed for the CV2MIDI converter (Program 5).
This program interprets a 5V input at a clock jack as "lock", where the sequence executed by the CV2MIDI converter changes the sequence direction, so you can define a new sequence length.
But if you define the lock as CLOCK based the sequence cursor sometimes returns at the lock position, and sometimes not. The sequence gets a randomized length.
The situation becomes really weird if you define 2 CLK locks at different positions in the sequence with different speed rates.
Then the sequence cursor is caught in different parts of the sequence at different times like a lost ping-pong ball jumping to random segments.
Posted Image
Above: PCBurger and Pasta ๐Ÿ”๐Ÿ
Posted Image
Above: As purely analog, channel CV adjustments on the back side
Posted Image
The Circuit
Posted Image
Above: Schema of a single channel
Each PCB (2 channels) has its own PSU adaptor, as the LEDs consume a lot of current.
Both front panel pots are 1k.
The CV unit (U2) operates from exactly 0V to 5V adjusted with the OFFSET and AMPLITUDE trims.
The LFO (A5) operates from 1Hz to the lower audio range.
The clock operation selection logic (Q1, Q4) is controlled by the front panel switch (J5). The clock output modes are set to 0V and 5V and provided at the output via the discrete "OR" logic of Q2 and Q3.
Offer
Spare PCBs, Gerber and LtSpice files can be obtained directly from me, just send me an email (No PM!).
electrotech
PostPosted: Wed Aug 27, 2025 2:28 am    Post subject: Reply with quote  Mark this post and the followings unread
That's a very impressive (& professional) build you've done there.
I also like the use of the old resistors with the value printed on them rather than those modern five-band ones with indecipherable colours !
Andy
analogmonster
PostPosted: Thu Aug 28, 2025 10:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
Andy
Thanks ๐Ÿ˜Š
I must admit that I've never seen such resistors before ๐Ÿ˜ฎ๐Ÿค”
Here the next level: I added ratcheting as new program to the CV2MIDI converter:
The Peasant
PostPosted: Fri Aug 29, 2025 7:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi everyone!
I finally finished the videos for my tube synth:
https://youtu.be/FPosNWLeFhI
https://youtu.be/f6_HdbAmGvQ
Take care,
Doug
The Electronic Peasant
www.electronicpeasant.com
Audio files: 32
PostPosted: Sun Aug 31, 2025 5:19 am    Post subject: Reply with quote  Mark this post and the followings unread
Very Cool, thanks for sharing!
my synth
Audio files: 83
PostPosted: Sun Aug 31, 2025 9:13 am    Post subject: Reply with quote  Mark this post and the followings unread
It sounds great! Good job Smile
JacobWatters.com
analogmonster
PostPosted: Mon Oct 06, 2025 7:00 am    Post subject: Formant++;
Subject description: PSU
After 16 years on duty, the control board of the PSU of my Formant Modular Synthesizer passed away ๐Ÿ˜ข
As the 723, its socket and the PCB underneath melted and baked together, nothing could be repaired, so I had to develop a new PCB for it. Same circuit, same board size, as everything shares the same free space within the keyboard enclosure together with the keyboard interface which I wanted to save in any case: It was a lot of work due to 8 voice polyphony, key velocity detection, joystick X-Y - control and MIDI monitor...
Posted Image
Available space:
Posted Image
PSU control board added:
Posted Image
Keyboard electronics addad:
Posted Image
Complete: Everything runs again ๐Ÿ˜Š
Posted Image
vladosh
Audio files: 55
PostPosted: Sat Dec 06, 2025 9:03 am    Post subject: Reply with quote  Mark this post and the followings unread
Here's something i finished . It's a groovebox ,sort of .It features Experimental Hardware Neurons from Wiard as the trigger sequencer ,voices include 2 x Hagiwo Samplers ,1 x Hip Bass Drum from Craig Anderton and two NLC Bong0's stripped to only two inputs and an output . There is also 194 Buchla Bandpass Filter and 106 Buchla Mixer ,99dsp Effects from Aliexpress ,a Colorupter Optical Compressor ,and 208 Uncorelated Random from Buchla paired with CD4052 Pattern generator to sequence thru the sample select or sample banks.
Posted Image
http://synthacks.blogspot.com/ ัˆะตะผะฐั‚ะธะบั
analogmonster
PostPosted: Mon Dec 15, 2025 6:40 am    Post subject: FM Drum Synthesizer
Subject description: My implementation of the Erica Synths project
I decided to implement the Erica Synths FM Drum Synthesizer with some (small) extensions. The Carrier CV nonreturn diode can be bridged to add some distortion (frontpanel element "TRASH - OFF - METAL"), and I added a Gate LED.
Posted Image
Posted Image
Posted Image
My YouTube example shows some first primitive integration tests. The Cymbal sounds a bit harshly due to the 4 diode ringmodulator.
analogmonster
PostPosted: Fri Jan 30, 2026 12:42 am    Post subject: Erica Synths FM Drum Synthesizer
Subject description: More complex sound example
A more complex sound example: Just uploaded my nasty remake of M.A.R.R.S.โ€™ Pump Up the Volume and a Fortnite emote. All sounds are made with the FM Drum Synthesizer with some delay added on the toms. The toms and cymbals are voltage controlled via Carrier CV extension from a MIDI track:
analogmonster
PostPosted: Sun Feb 15, 2026 6:56 am    Post subject: Instrumentation amplifier cascade
Subject description: Generic helper module
I built another instrumentation amplifier cascade, this time for my third modular, the Analogmonster Modular. Each stage is a DC coupled cascadable mono amlifier of U(out) = -9.09 * U(in), used for amplification of weak DC or AC signals, e. g. low leveled outputs of other instruments.
Posted Image
Posted Image
Posted Image
analogmonster
PostPosted: Fri Feb 20, 2026 2:00 am    Post subject: Re: FM Drum Synthesizer
analogmonster wrote:
I decided to implement the Erica Synths FM Drum Synthesizer with some (small) extensions...
This track uses the kick drum function and two different snares / hihats.
The Peasant
PostPosted: Wed Sep 09, 2026 10:58 am    Post subject: Reply with quote  Mark this post and the followings unread
I don't see a Build Pictures 2026 thread, so I will post this here.
My latest project is a handy little utility box for my modular:
Posted Image
It does VCO transposition and octave switching, as well as audio and CV signal switching. Built entirely using discrete logic chips as well as a few op amps.
Posted Image
Posted Image
The module includes a pair of six-octave latching switch banks, a one-octave switch keyboard, and four SPDT analogue switches. There is a combined output that mixes one of the octave switch banks with the keyboard output so that they can be used together, and the keyboard has a gate output included as well, so that it can be used as a freestanding keyboard.
More information and full schematic on my website:
https://www.electronicpeasant.com/projects/transwitch/transwitch.html
Take care,
Doug
analogmonster
PostPosted: Wed Sep 09, 2026 10:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
Nice design! Is there a reason you did not implement this as a module?
The Peasant
PostPosted: Thu Sep 10, 2026 8:10 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks! For this project I wanted something that sat on my desk and not up in the rack, it just fits my workflow better.
Take care,
Doug
