Reading a Japanese city-pop vinyl listing: pressing, obi and condition
RenSynthJp
PostPosted: Sat Oct 03, 2026 3:05 pm    Post subject: Reading a Japanese city-pop vinyl listing: pressing, obi and condition Reply with quote  Mark this post and the followings unread
City pop has become easy to discover and surprisingly hard to buy intelligently. The same album may appear as an original Japanese pressing, a later domestic reissue, a recent repress, a 7-inch single, or a listing assembled from a stock photo. Before comparing prices, I now reduce every Japanese listing to five pieces of information: catalogue number, pressing, included paper parts, record condition and jacket condition.
1. Start with the catalogue number
Artist and album title are not enough. Mariya Takeuchi, Tatsuro Yamashita, Anri, Taeko Ohnuki and Toshiki Kadomatsu all have records with multiple issues. The number printed on the spine, label and runout-area references is the quickest way to distinguish them. Search that catalogue number by itself and compare the label design and release year with a discography database.
Japanese listings often use 初版 or オリジナル盤 for an original issue, 再発盤 for a reissue, and 復刻盤 for a reproduction/revival edition. These are seller descriptions, not independent certification, so the physical identifiers still matter. A recent repress can be excellent for listening; it is simply a different object from an early pressing.
2. Treat the obi as a separate component
帯付 means the obi strip is included. 帯なし means it is absent. The obi may have fading, a tear, writing or tape even when the jacket is clean, so “obi included” should never be interpreted as “perfect obi.” Look for 帯破れ (torn obi), 帯傷み (obi wear) and 日焼け (sun fading).
The insert, lyric sheet and poster are separate again. ライナー is a liner-note sheet; 歌詞カード is a lyric sheet; ポスター is a poster. 付属品 is the general word for included accessories. A complete-looking cover photo tells you nothing about what is inside unless the description or additional photos show it.
3. Grade the disc and sleeve independently
Japanese sellers mix international abbreviations such as NM, EX and VG with their own scales and plain-language notes. 美盤 usually means a clean-looking disc, while スレ means scuffs, キズ means scratches, and 反り means warping. ノイズ is noise, 針飛び is skipping, and 再生未確認 means playback was not checked.
For the jacket, 角打ち means bumped corners, 底抜け is a split bottom seam, 背割れ is a split spine, and シミ is staining or foxing. A visually clean record inside a split sleeve may be fine for listening but wrong for a collector shelf. Ask for clarification when a listing gives one overall grade instead of separate disc and sleeve notes.
4. Do not confuse “looks clean” with “play-tested”
目視確認 is a visual inspection. 再生確認済み says playback was checked, but it may still not describe the entire record. A useful listing states whether noise occurs, whether it is continuous, and where it appears. Cleaning can remove dust and static; it cannot undo a deep scratch or groove wear.
For expensive copies, photographs under angled light are more useful than a front-on image. They reveal scuffs and spindle marks that disappear in diffuse lighting. The seller's words remain claims, so preserve screenshots of the photos and condition description before purchase.
5. Read the listing scope
LP, 12インチ and 7インチ describe different formats. 見本盤 or サンプル identifies a sample/promo copy. ジャンク means as-is/parts condition, not a precise diagnosis. レコードのみ means the record only. セット and まとめ売り indicate a set or bulk lot, but neither means that every pictured title is included; check the written inventory.
Packing is part of the record's condition
International shipping introduces risks that were not present in the listing. A rigid LP mailer, corner protection and sensible void fill matter. For valuable jackets, collectors often ask that the disc be placed outside the jacket but inside the outer sleeve during transit, reducing seam splits. Whether a seller or forwarder can accommodate that request should be confirmed rather than assumed.
One more cost trap is evaluating an LP by item price alone. Domestic postage, service fees, packing choices, the final carton dimensions and international shipping all affect the landed cost. Combining records may help, but the result depends on the packed shipment and carrier quote; there is no universal saving percentage.
Disclosure: I am affiliated with the OneMall team, a Japan proxy-shopping and forwarding service. I adapted this checklist from our longer Japanese city-pop vinyl guide, so that source is commercial rather than independent advice. OneMall does not independently verify records or warrant seller condition claims.
For people who buy Japanese pressings: which listing detail has saved you most often—the catalogue number, the obi photos, or a specific condition phrase?
