 Forum index » Clavia Nord Modular » Editor programs
New Open-Source G2 Editor RFC
Page 4 of 4 [93 Posts]
nord_balls
PostPosted: Mon Sep 14, 2026 8:52 am    Post subject: Reply with quote  Mark this post and the followings unread
So much activity now compared to when I started this thread in 2024! There are now _four_ editor projects:
G2FX (mine): https://github.com/sirlensalot/g2fx . JavaFX desktop GUI, cross-platform (packages for macos ARM and windows ARM for now)
G2-Edit (Chris'): https://github.com/chrispurusha/G2-Edit . C desktop GUI/VST plugin, MacOS ARM/Intel
g2-webeditor: https://github.com/ty-art-ty/g2-webeditor . Browser-based UI (Typescript, Java backend), headless Linux/raspberry pi server.
NordModularG2-Editor: https://github.com/JanBurp/NordModularG2-Editor . C Daemon + Electron shell GUI, cross-platform (macos ARM/intel, windows intel)
Mine has probably the least developer velocity Sad I'm still getting around to getting LLM help while the others are living in the modern age slinging features like nobody's business . I can at least feel good for (a) g2webeditor vendoring my USB library and (b) starting this thread!
Regardless G2 users are finally going to have modern options to keep making music with the best poly synth ever.
ChrisPurusha
PostPosted: Mon Sep 14, 2026 8:57 am    Post subject: Reply with quote  Mark this post and the followings unread
Yep. It’s all good. Burpy and I have been working together on some mechanisms. He did some work on mine, before heading off in his own direction.
nord_balls
PostPosted: Mon Sep 14, 2026 9:08 am    Post subject: Reply with quote  Mark this post and the followings unread
The one thing I did make some progress on was Windows ARM packaging. Not having a physical box (only tested on VMs in Azure), I wasn't able to see if the USB connections are working.
So if there are any Windows 11 ARM users out there, would love to find out if the USB library is working. The app is pretty safe atm as it has no storage yet Smile but many editor features working. What I'd like to know is if a physically-connected G2 shows up in the UI, patch browser etc.
Windows ARM package: https://github.com/sirlensalot/g2fx/actions/runs/28305223473/artifacts/7929145257
(The macos ARM package is also available, for the curious: https://github.com/sirlensalot/g2fx/actions/runs/28305223473/artifacts/7929140883 . I'll ask for more testing help once storage is going).
ChrisPurusha
PostPosted: Sun Sep 27, 2026 6:38 am    Post subject: Reply with quote  Mark this post and the followings unread
Just dropped a big beta update!
All modules now have some kind of sound engine implementation, but not all complete.
For those who are able to help start testing, You may need to give me copies of any patches which are not quite right. If you can simplify them to cover the module connections which are causing the divergence, even better.
Release notes link to a status document, which describes where each module should be status-wise.
ChrisPurusha
PostPosted: Sat Oct 03, 2026 6:49 am    Post subject: Reply with quote  Mark this post and the followings unread
All roughly 170 modules (apart from MIDI NoteSend, which is performance mode related) now populated and pretty-much working - including the ones not covered by the original editor. May be some gain/level issues or tweaks to make, so please report anything which doesn't sound like the hardware G2. Might have found a small gain issue on a complex patch already. Will check later today.
Try out your usual patches and if they sound wrong, send a copy over to me for testing. All the patches I've tried, actually sound pretty-good imo!
This will need collective testing to get right. Thanks all!
Burp
G2 patch files: 7
PostPosted: Sun Oct 11, 2026 12:03 am    Post subject: Reply with quote  Mark this post and the followings unread
Also a big update from my editor:
I just release the next version (v0.7.0) of my editor. A major big update! Almost everything the original clavia editor can do is implemented. With some UX and patching improvements. The only things missing are the Patch Mutator and Adjuster and the bigger panel with all Parameter Assignments. I will implement those in the next big update.
https://janburp.github.io/NordModularG2-Editor/
I also made a video: https://www.youtube.com/watch?v=B54kW9GCC20
My focus lies on a familiar and friendly UX.
if you don't know where you're going, you will allways arrive
Burp
G2 patch files: 7
PostPosted: Sun Oct 11, 2026 12:07 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes this! Realy nice. And i like it a lot that there are now four alternatives! We are all different users with different wishes and uses cases. My hope is that all these editors will fit those different uses and our beloved G2's will live on.
ChrisPurusha
PostPosted: Sun Oct 11, 2026 7:48 am    Post subject: Reply with quote  Mark this post and the followings unread
Just made a new release with lots of sound engine improvements, but also my first go at writing a new module (which won't load on the G2) - an experimental sample playback module which loads Emu sample bank samples. Also loads some Nord sample presets. Started to include some time-stretching effects on it too, but they're not really doing the right thing yet.
Burp
G2 patch files: 7
PostPosted: Sun Oct 11, 2026 10:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
A minor update is ready (some small fixes and typos): https://janburp.github.io/NordModularG2-Editor/getting-started/
ChrisPurusha
PostPosted: Wed Oct 21, 2026 12:57 am    Post subject: Reply with quote  Mark this post and the followings unread
I've taken a slight diversion from the G2 editor project, to see if the capture an analysis tools I now have, will capture and reproduce analogue circuitry. So, just-in-case anyone's interested, there's now a Waldorf Pulse 2 reproduction plugin for MacOS in my GitHub pages's repositories. A few more potentially interesting tools too.
Edit: Also, new link to my renamed G2 repo below. Currently offline but planning to re-publish this coming weekend (24th Oct '26).
https://github.com/chrispurusha/G2Alike
Burp
G2 patch files: 7
PostPosted: Thu Oct 22, 2026 8:42 am    Post subject: Reply with quote  Mark this post and the followings unread
Mine has a bigger update full of fixes and UX finetuning (v0.7.2): https://janburp.github.io/NordModularG2-Editor/
In next couple of weeks i will also release (v0.8.0) wich will include some new features, including the much asked for Patch Mutator (and Patch Adjuster, big Parameter Pages Overview, and more)
Audio files: 267
PostPosted: Thu Oct 22, 2026 1:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
Burp and Chris,
Are you both using AI for coding? If so I'll start a topic to discuss this in the discussion forum. I've been using Claude upgrade this site. It would be good to share experiences.
EDITORS NOTE: Burp replied to this comment of mine with an excellent post about his experience. Whith his permission I'm will the post to a new topic I started.
ChrisPurusha
PostPosted: Sun Oct 25, 2026 9:57 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi. I started doing my work without AI, but the sound engine has been AI assisted.
Partly why my GUI isn't as fancy as the others.
By the way, in case anyone hasn't seen it - Usual Suspects have announced a full host emulation, not yet test released. Apparently has an editor in there too.
Great news, but I reckon since my implementation is fully native and modifiable, it has something US won't have. Smile
cube666999
PostPosted: Mon Oct 26, 2026 1:26 am    Post subject: Reply with quote  Mark this post and the followings unread
My editor, written in Swift for Apple Silicon, is missing from this list: https://cubeg2.github.io/
ChrisPurusha
PostPosted: Mon Oct 26, 2026 9:53 am    Post subject: Reply with quote  Mark this post and the followings unread
Note the repo name for my plugin changed from ...G2-Edit to ...G2Alike as per my recent post, not the link in nord_ball's list.
By the way, I've decided I'm now out of beta, since I've auto-validated every module sound-engine-wise. A few niggles to work out, but I think it's all sounding pretty much there now.
Burp
G2 patch files: 7
PostPosted: Sat Oct 31, 2026 2:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
Let me present v0.8.0 of my Nord Modular G2 editor.
With:
* The Patch Mutator (yes it's here!)
* The Patch Adjuster
* Parameter Pages Overview -> with VU meters!
* Bank Organizer -> easy way of (re)organizing the internal memory of your G2.
* Find & Replace -> Find modules names and, or lables, and replace them, or delete the found modules
* Library -> Save a collection of your favourite building blocks. They are just plain .pch2 file, with some use of tags.
* And a lot of big and small changes and fixes
Download it here: https://janburp.github.io/NordModularG2-Editor/
Video of this version: https://youtu.be/JfptPZ5R9fo
Next version i will focus on a Linux build, and (hopefully) easier Windows USB drivers.
Burp
G2 patch files: 7
PostPosted: Fri Nov 06, 2026 2:08 am    Post subject: Reply with quote  Mark this post and the followings unread
I just released v0.8.1 with al lot of small UX tweaks and a lot of bug fixes (usb comms, patch parsing, patch loading, copy/paste in windows).
And i also made a special build release for Windows and Linux users to help me test. I both tested in on an emulated Windows11 and an emulated Ubuntu on my Mac. That works. But a real device test is needed.
- Windows: the editor will now install usb libraries itself, so no extra install is needed, also you can keep the Clavia driver so you can use both editors side by side.
- Linux: added build for Linux
You can download those builds here https://github.com/JanBurp/NordModularG2-Editor/actions/runs/42190882566 (you need a GitHub account for this).
ChrisPurusha
PostPosted: Fri Nov 06, 2026 2:51 am    Post subject: Reply with quote  Mark this post and the followings unread
Yeah - I'm using the same VM approach for Windows work (I don't have a dedicated Windows machine), so if anyone's able to test on Windows for my editor and sound engine - that would also be good.
