cybertribe
G2 patch files: 4
Posted: Sun Nov 08, 2026 6:53 pm Post subject:
Rave-O-Lution 309 Subject description: Quasimidi-Rave-o-lution-309 |
A Quasimidi Rave-O-Lution 309 groovebox, rebuilt for the Nord Modular G2.
This four-slot performance brings back the 309’s sound sections, its knob layout and its hands-on way of working.
Quick start
Choose a drum groove with the variation buttons of Slot D.
Choose a bass line with the variation buttons of Slot C. Matching numbers on C and D are made to go together, but any mix works.
Press Global and start turning knobs.
What’s inside
The performance is split over the G2’s four slots:
Slot A: Drums and Master. Kick, snare and hi-hat, plus the master section that everything plays through: reverb, tempo-synced delay, EQ, Overblast (bass boost), a compressor and the main volume.
Slot B: Perc Set. Twelve percussion sounds: clap, rim, clave, three toms, two congas, cowbell, shaker, crash and ride. As on the original, three knobs (Tone, Decay, Level) shape the whole set at once.
Slot C: Bass/Lead. A mono synth with its own 16-step acid sequencer, with notes, accents and slides. Sounds range from squelchy 303-style acid to sub bass, reese, hoover, rave leads, plucks and organ stabs.
Slot D: Drum Sequencer. Twelve tracks for all the drums and percussion, with accents and shuffle.
The 309 sound
What makes it feel like a 309 is the sound chain on every drum: a drive that pushes into a resonant 24 dB filter, followed by an envelope with attack and decay. Each drum also has a Wave knob that morphs it from a punchy 909 character to a deep 808 one.
Sound sets and patterns
Each slot has variations you can switch with its variation buttons. Variations 5 to 8 are spare copies for your own edits.
Slot A drum sounds: 909 Rave, 808 Deep, Hard Acid, Analog Dry
Slot B perc sets: 909 Perc, 808 Latin, Rave Perc, Deep Perc
Slot C bass/lead: eight different programs, each with its own line
Slot D drum patterns: Main, Main + Perc, Variation, Peak, Breakdown, Drop, Fill, Alt
The performances in the pack start on the drum and perc sounds that suit their style.
The knobs
Press Global and the G2’s knob pages become the 309’s front panel:
Page What the 8 knobs do
A1 Kick Wave, Attack, Decay, Tune, Level, Cutoff, Resonance, Drive
A2 Snare Wave, Tone, Decay, Tune, Level, Resonance, Drive, Env Mod
A3 HiHat Wave, Decay, Tune, Level, Cutoff, Resonance, Drive, Open Decay
B1 Perc Tone, Decay, Level, Perc On, Res L, Res R, Clap, Rim
B2 Bass/Lead Wave, Cutoff, Resonance, Env Mod, Accent, Glide, Level, Drive
B3 Bass envelope Attack, Decay, Sustain, Release, VCA Gate, Tune, Osc 2 Level, Osc 2 Pitch
C1 Bass LFO Wave, Rate, Depth, to Pitch, to Filter, to Volume, Velocity to Filter, Filter Type
C2 Performance Mute buttons for Kick, Snare, HiHat, Perc and Bass, plus Shuffle, Overblast, Volume
C3 Effects Reverb Time, Reverb Level, Delay Time, Delay Feedback, EQ Low, EQ High, Overblast, Volume
D1–D2 Kick steps 1–16
D3–E1 Bass note pitches, steps 1–16
E2–E3 Bass note on/off, steps 1–16
| Description: |
 Download (listen) |
| Filename: |
RAVE-O-LUTION 309 G2 v2.prf2 |
| Filesize: |
20.89 KB |
| Downloaded: |
17 Time(s) |
