Coming up on Radio 1 at
 Forum index » Clavia Nord Modular » G2 Performances - Completed
TR-909 G2 Performance
cybertribe
G2 patch files: 4
PostPosted: Sun Nov 08, 2026 8:58 pm    Post subject: TR-909 G2 Performance
Subject description: Roland TR-909 rebuilt for the Nord Modular G2
A Roland TR-909 rebuilt for the Nord Modular G2 as a four-slot performance. All 11 voices are synthesized from scratch . It has the 909-style sequencer, and the 909’s front panel laid out on the G2’s knobs.
How it’s built
The performance uses all four slots. The two drum slots (B and C) send their audio over the G2’s inter-slot buses into Slot A, so everything shares one master bus. The sequencer in Slot D plays the other slots with internal MIDI notes. Every block in the editor has a labelled header bar and its own colour.
Slot A: Bass Drum, Snare, Master
Bass drum: an OscB sine oscillator that restarts on every hit, for a consistent attack. Two EnvD envelopes make the pitch sweep, a fast drop for the punch plus a slow tail, and accent deepens the sweep. An EnvAHD gives the held body. The click is white noise through a velocity-controlled FltLP, plus a short envelope “beater” spike. It ends with Saturate drive (harder on accents), a DC-blocking high-pass, and a “Round” low-pass.
Snare: two OscA triangle oscillators (about 185 and 330 Hz) with a short pitch kick and their own EnvD decays. The noise runs through FltHP and FltLP (the Tone knob), with a little sample-rate grain. Snappy sets the noise level.
Master: in the FX area. It mixes all three slots into a bus Compressor, Saturate “warmth” and LevAmp makeup gain, with BD and SD also sent dry to Out 3/4. The kit FX are one Reverb behind a 300 Hz high-pass and one tempo-synced DlyStereo, fed by per-voice and per-group sends.
Slot B: Toms, Rim Shot, Hand Clap
Toms: OscPerc oscillators with an EnvD pitch drop and a little filtered noise.
Rim shot: two pinged OscPerc resonators through a high-pass.
Clap: band-passed noise retriggered three times in 30 ms (an LfoB burst gated by a Pulse window), plus a separate, darker EnvAHD tail with its own filter.
Slot C: Hi-Hats and Cymbals
Hats: MetNoise metal with a little white noise, through a 24 dB high-pass and two resonant FltStatic peaks. Closed and open share one ModAHD envelope, so closed always cuts open, and an S&H “open flag” lengthens the decay for open hits.
Crash and ride: the same metal-and-peaks design. The ride adds a ring-modulated bell made from two square-wave oscillators.
Shared processing: a Digitizer adds 6-bit, 32 kHz grit, and a low-pass rolls off the top.
Slot D: Sequencer
Clock: a ClkGen follows MIDI clock and provides the shuffle. Clock dividers and a 4-way switch give the four 909 scales.
Tracks: 18 SeqEvent sequencers hold bar A, bar B, accents, flams and the last-step marker.
Chaining: toggling clock dividers with logic gates run the AB and AAAB chains.
Velocity and flam: velocity is a normal level plus instrument accent plus Total Accent. Flams come from a logic Delay with one shared interval.
Output: NoteSend modules play the drum slots and echo every hit to MIDI out.
Small touches
Morph-group knobs: Crash and Ride Tune each move pitch, filters and decay at once, and Volume and Warmth each control both stereo sides.
Per-hit drift: a tiny random pitch offset on each hit, like analog drift.
On buttons to mute every voice.
Features
All 11 TR-909 voices: BD, SD, three toms, RS, HC, CH, OH, crash, ride.
The 909 sequencer: 16 steps, total and instrument accents, flam, shuffle, four scales, last step.
Two-bar patterns: AB or AAAB chaining, with 8 patterns included: Techno, House, Tekno, Detroit, Electro, Roll Fill, Triplet, Empty.
Four sound sets: Round, Round Punch, Round Deep, Crisp.
Outputs and MIDI: BD on Out 3 and SD on Out 4. MIDI in on channel 10 with the 909 note map; MIDI out on channel 11.
How to use
Load the performance and press Run, or send MIDI clock and Start.
Pick a pattern with Slot D’s variation buttons, and a sound set on Slots A–C.
Press Global, and the knobs become the 909 panel:
A1: Kick and Snare.
A2: Toms.
A3: Rim, Clap, Hats and Crash.
B1: Ride, Accent, Shuffle, Scale, Chain, Volume.
B2: mute buttons.
C3: reverb and delay.
D1–E3: step buttons for Kick, Snare and Closed Hat.
To play from pads or a DAW, use MIDI channel 10: kick 36, rim 37, snare 38, clap 39, toms 41/45/48, closed hat 42, open hat 46, crash 49, ride 51.
TR-909 G2 v9.prf2
 Filename:  TR-909 G2 v9.prf2
 Filesize:  24.6 KB
 Downloaded:  10 Time(s)
