Lionel
Joined: Sep 15, 2026 Posts: 2 Location: Kingston upon Hull
Posted: Tue Sep 15, 2026 8:21 pm Post subject:
Which microphone and which bowl are best for harmonics? |
Hi. I'm currently working on some fairly long drones for my Eurorack setup, and the idea was to start with a rich acoustic source rather than generating everything synthetically. So two or three weeks ago, I borrowed a Tibetan singing bowl from my sister (she meditates, so she has several) and set up a little recording session at my place in Nantes. My son was there that weekend; he was pretty curious about it and even tried to make it sing with the mallet while I was adjusting the levels.
It took about two hours in total, between setting up the mic, testing different distances, and recording takes with and without the room’s natural reverb. I used a fairly standard condenser mic, around 300 euros, the same one I already use for vocal recordings. The result was interesting to work with later in the patch full of harmonics to filter and modulate. Well, after doing a bit of research afterward, I asked myself a question perhaps a silly one: Is there a real difference in the harmonic spectrum depending on the bowl? Like, does the best Tibetan singing bowl really sound different through a condenser mic, or is it mostly the recording technique the distance, the angle, the room that does all the work? With a synth, I know exactly what I’m looking for; with this, much less so. If anyone here has already sampled somewhat exotic acoustic sources like this to feed a modular synth, I’d love to hear your feedback. |
Joined: Jan 31, 2003 Posts: 18545 Location: Durham, NC
Audio files: 267
Posted: Mon Oct 05, 2026 9:40 am Post subject:
My experience may not be typical, but I have many microphones, condensers and dynamic. While careful listening will show up differences, they a very subtile. Aside from being an electro-musician I'm a radio amateur. In both worlds there are many opinions.
Personally, I have given up on worrying about mics. I use Sure SM57 and SM58 for everything except for in the field where I use a Zoom H5.
My most annoying problems with mics is feedback when used with sound reinforcement. Then mic placement seems to bite me all the time. Take one step in any direction and everything is different.  _________________ --Howard
my music and other stuff |
FatBerryDSP
Joined: Nov 11, 2026 Posts: 22 Location: United Kingdom
Posted: Fri Nov 13, 2026 1:57 pm Post subject:
For singing bowls the room and the placement usually matter more than the mic. A few things that tend to help capture the harmonics:
1. A small-diaphragm condenser gives a flatter, more detailed top end and better off-axis response than most large-diaphragm mics, which helps with all the partials ringing round the rim. Your current condenser is perfectly usable though.
2. Distance. Too close and the fundamental and the beating dominate. Try 30 to 60 cm above and slightly to the side of the rim, and move it while the bowl rings to find where the upper partials bloom.
3. Stereo. A spaced pair or an XY pair really helps, as the beating between partials moves around the bowl. For drone sources that movement is gold.
4. Quiet, dead-ish room. Bowls ring for a long time, so any room tone or noise ends up in the sample. Blankets round the space help a lot.
5. Striking versus rubbing. Rubbing with a suede or rubber mallet gives a steadier, more sustained tone, which is easier to loop for drones. Striking gives more partials at the start.
6. Bowls. Hand-hammered bowls usually have richer, less regular partials than machine-made ones, and heavier bowls have a lower fundamental and longer sustain.
Record at 24-bit with plenty of headroom, as the attack can be much louder than the sustain. _________________ Fat Berry DSP team | https://fatberrydsp.com/?utm_source=forum-electromusic&utm_medium=social&utm_campaign=free-pickings&utm_content=forum-berry-261113-signature |
