tri via lis ati on
Page 3 of 3 [58 Posts]
Goto page: Previous 1, 2, 3
luftballon
Audio files: 9
PostPosted: Sat Nov 07, 2026 7:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
And why is it that the listen count on my track gets upped every time it reloads the page (without listening) as if the ai-ai-ai-bots do not suck enough data already . anyway .. those numbers are useles, incorrect and sensless . leave them out if you can not calculate them .. leave them out when you can not control the bothounds .. it is nonsense.
________________
jan.
luftballon
Audio files: 9
PostPosted: Sat Nov 07, 2026 8:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
Anyway .. this :
this 4 now .. now for this .. it is all fluctuations .. eternity is the hope for later
 Filesize:  225.71 KB
 Viewed:  19 Time(s)
________________
jan.
luftballon
Audio files: 9
PostPosted: Fri Nov 13, 2026 4:30 pm    Post subject: Reply with quote  Mark this post and the followings unread
luftballon wrote:
Hmm .. I can not find it .. but it came true it seems .. and it predicted :
I'm all pro gress currently .. some stuff into the top row.
But now I dont dare connect stuff .. affraid that I made a power line fault .. even when I like tripple checked .. Shocked
So eh .. cheapest module first I guess .. as the 4thh check.
But maybe it tshould all go out again .. I still need a couple of LEDs for the power .. a switch for the fan .. and actually a 2nd 60mm fan ..
So might as well paint the woodwork .. dark grey I guess.
And I'm still looking for a suitable oscillator, some VCLFO stuff .. a loopable envelope with time control on voltage .. and hardware that I can easily add I/O too and program myself .. but with not only plenty of ins, but also plenty of outs .. so maybe I'm just going too fast.
some top row stuff
 Filesize:  305 KB
 Viewed:  14 Time(s)
________________
jan.
luftballon
Audio files: 9
PostPosted: Sat Nov 14, 2026 2:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
Cool, it did not explode .. but the openings are a tad small .. need fix that too.
some more row stuff and a light :)
 Filesize:  447.23 KB
 Viewed:  19 Time(s)
________________
jan.
luftballon
Audio files: 9
PostPosted: Sun Nov 15, 2026 5:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
Also made my 1st 1U (actually a lil bit higher) module today, power LEDs Smile
Module Smile
Tomorrow I may be finishing the 2nd unit (with four pots .. voltage generator, or constant module in Wren or NM speak).
Probaly a -12 to 12, a 0 to 12, a -12 to 0 and a 0 to 5 out. They will be a tad silly high impedance .. but I'll have volt meter ready for when it matters .. or maybe I'll find some opamps .. will see.
At lest it will look a little bit better too Cool
That's the fun thing about just soldering things up .. can decide last minute.
The maybe less fun thing is .. it doesn't look so profi ..but as long as it doesnt crackle & do it'll be fine.
But today it was my first excercise with semiconductors in like .. hmm .. decades I guess? 5mA worked fine (2k2 & 680Ω) .. old LED's Smile
I'm still looking at a nice programmable platform thing . mainly for LFO rate stuff .. but I'll want a good couple of outputs ..i may just go do old fashoned PIC Shocked
Oh and the fan stopped working (soem maybe that was the reason for the NAS it came out to have died?) .. but it seems to not be needed, will see Smile
And I was a bit worried that the mean well RT-65B might be a bit low on power, especially on -12V, but sofar it seems ok for the purpose (about 160HP of 3U & 80 HP of 1U modules).
my kof 001 module :)
 Filesize:  24.08 KB
 Viewed:  524 Time(s)
________________
jan.
luftballon
Audio files: 9
PostPosted: Mon Nov 16, 2026 11:13 am    Post subject: Reply with quote  Mark this post and the followings unread
a bit different .. still constants though.
The schneider stuff was shipped they aid .. some modules I had expected friday will be delayed a bit.
Maybe should make a pair of 1/4" outs .. the golden master is able to do balanced outs it says .. so now to sort out how to do balanced outs that auto switch to unbalanced with a TR instead of a TRS plug,
kof 02
 Filesize:  359.21 KB
 Viewed:  11 Time(s)
________________
jan.
luftballon
Audio files: 9
PostPosted: Mon Nov 23, 2026 5:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
Some more modules .. waiting for one more for the top left .. a waveform display thingie ..
Oh and three more simple thingies .. lfo . envelope ..
And then it will need some thought .. as to what to fill the gaps with.
I will not add the 0-stuff or the taiga to the suitcase but leave that on their own.
I am still looking for a suitable processor thingie with plenty I/O at control rate .. mostly.
And meanwhile .. till the suitcase starts exporting audio .. I fell back to a little Wren noodle thingie Cool
And that is what processor thingie would be for .. to port some Wren thingies. I did get an old pickit-3 btw .. and some PIC may even be suitable for control rate stuff . needs thought as well.
s 10 03.mp3
blue hell - generative lulaby with wren :)
 Filesize:  14.12 MB
 Duration: 15:26
 Viewed:  231 Time(s)
kof 2026 11 23 01
 Filesize:  365.43 KB
 Viewed:  6 Time(s)
________________
jan.
luftballon
Audio files: 9
PostPosted: Tue Nov 24, 2026 12:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
Meanwhile there is 1st sound :) (it uses bits of Wren)
Desperately in need of modulation and mixing .. I think :)
kof 2026 11 24 01.mp3
blue hell - kof 2026 11 24 01
 Filesize:  7.95 MB
 Duration: 8:16
 Viewed:  179 Time(s)
kof 2026 11 24 01
 Filesize:  346.58 KB
 Viewed:  6 Time(s)
________________
jan.
