Brief maintenance shutdown at 10:00 PM EST - 0400 UTC
Coming up on Radio 1 at
 Forum index » Clavia Nord Modular » G2 Patches - Completed » External Control
Arturia Minimoog controller patch
Page 1 of 1 [2 Posts]
BobTheDog
Audio files: 32
PostPosted: Sun Apr 30, 2006 4:36 am    Post subject: Arturia Minimoog controller patch Reply with quote  Mark this post and the followings unread
Here is a controller patch for the Arturia Minimoog V softsynth.
Most things can be controlled apart from :
tune 440 tone on/off
Chorus type
Delay midi sync
Bend on/off
Modulation sources and destinations
Bend range
You need to copy the controlMidi file (inside the zip) to the save folder for your minimoog installation.
I am working on another version with a simple sequencer in it.
All the Best
Andy
MiniMoog Ctrl.pch2
Arturia minimoog V controller patch version 1
 Filename:  MiniMoog Ctrl.pch2
 Filesize:  5.49 KB
 Downloaded:  2596 Time(s)
controlMidi.zip
Unzip this to the Save folder of your minimoog installation
 Filename:  controlMidi.zip
 Filesize:  660 Bytes
 Downloaded:  1249 Time(s)
BobTheDog
Audio files: 32
PostPosted: Sun Apr 30, 2006 5:55 am    Post subject: Reply with quote  Mark this post and the followings unread
A new version already!
Some things had got garbled!
Osc range and wave now use switches so you can see the values on the G2 display.
Moved around some of the controls to make it more consistent, i.e all osc vols in same column on G2 display.
Andy
MiniMoog Ctrl.pch2
New version, makes a bit more sense
 Filesize:  5.49 KB
 Downloaded:  2489 Time(s)
