Hyde
Posted: Fri Jun 16, 2006 7:17 am Post subject:
| paul e. wrote: | | it's better to be orginal and experimental, than worry about copying another's sound..imo |
that's a cop-out man just because you can't figure it out. that 'sound' was used on 1 freaking tour for 1 song 14 years ago by a band that has since disbanded. (sigh...) |
Audio files: 21
Posted: Fri Jun 16, 2006 8:10 am Post subject:
Stupid Paul! Excuses...
Honestly, I think Paul is trying suggest a creative approach to the "problem". Anyways, I am not seeing the problem myself. Lift the input feed close to clipping in the first stage of the Boss unit. Adjust the settings in ordre to get a similar modulation.. then brickwall the output in order to further amplify the modulation effects. Sounds like Patton is using a dynamic mic like one of those cheap Shure ones. _________________ A Charity Pantomime in aid of Paranoid Schizophrenics descended into chaos yesterday when someone shouted, "He's behind you!"
Flickr |
Posted: Fri Jun 16, 2006 9:00 am Post subject:
| Unfed wrote: | yeah, sounds like a distorted pitch-shift of sorts.
have you heard the albums 'Too Dark Park' or 'Last Rights' by Skinny Puppy? the vocalist uses this effect a bit, it sounds better than in this example. |
Dave Rave (who engineered those) is a genius. Nearly everything he does on vocals involves using several different effects in paralel. He also did "downward spiral" era NIN and manson around the "antichrist superstar" days. _________________ Kassen |
Joined: Jan 31, 2003 Posts: 18543 Location: Durham, NC
Audio files: 267
Posted: Fri Jun 16, 2006 9:01 am Post subject:
Steve, thanks for the link to the fair use background information. Very helpful. I learned a lot. _________________ --Howard
my music and other stuff |
paul e.
Joined: Sep 22, 2003 Posts: 1567 Location: toronto, canada
Posted: Fri Jun 16, 2006 12:39 pm Post subject:
| Hyde wrote: | | paul e. wrote: | | it's better to be orginal and experimental, than worry about copying another's sound..imo |
and somehow you want to copy it..? so you can go on a worldwide tour i guess...
people come up with orginal sounds by expermenting and usually combining many elements...it's what make them 'artists' ...to be orginal..
you are looking for a paint-by-numbers approach...
good luck
Distorted Pitch Shifting for Dummies... do they have that book out yet? _________________ Spiral Recordings |
paul e.
Posted: Fri Jun 16, 2006 1:08 pm Post subject:
btw..i think the answer to your 'problem' has been carefully laid out in this thread by a number of helpful people...seemingly not satisfactory to you...have you even tried those solutions ???
what's up with that (sigh...) ?
your attitude got me to the point where it is like:
ok then, figure it out yourself......have fun and share your results if you want _________________ Spiral Recordings |
Unfed
Joined: May 11, 2004 Posts: 200 Location: Rochester, NY
G2 patch files: 11
Posted: Fri Jun 16, 2006 3:29 pm Post subject:
| Kassen wrote: | | Dave Rave (who engineered those) is a genius. Nearly everything he does on vocals involves using several different effects in paralel. He also did "downward spiral" era NIN and manson around the "antichrist superstar" days. |
actually, i think he had much more of a production hand in SP up until The Process. looking now, it seems he didn't do really anything with NIN until after he had remixed 'Reptile'. he's not credited on The Downward Spiral. he did work on 'The Perfect Drug', a few more remixes, and is credited with 'additional mixing' on The Fragile. but yeah, as much as i don't like Marilyn Manson, Antichrist Superstar really is a hell of an album. you can tell Ogilvie had a bit more to do with that one.
Hyde - sorry, that was a pretty broad example. i'll try to see which tracks in particular use this effect. actually, i believe 'Anger' off of the album Cleanse, Fold, & Manipulate uses an extreme version of this (??). _________________ SoundCloud |
Hyde
Posted: Fri Jun 16, 2006 3:31 pm Post subject:
elektro: yes - he uses an old version of the SM57 almost exclusively. and again, i have tried adjusting the settings to get a similar modulation but i can't nail it down, which is why i asked if the G2X Engine could produce this effect and produce it better.
paul: i asked if anyone wanted to take a stab at replicating this sound in the G2, because i have been unsuccessful in doing so. you dont know me and you haven't heard any of my music. so stfu about this 'paint by numbers' bs.
i shouldn't sing through a boss se-50 because it's been done before. i shouldn't use a shure sm-58 mic because someone else has used one before. people shouldn't use the wah-wah effect on their guitars because its been done before. people shouldn't use distortion on their vocals or any other instrument for that matter because it's unoriginal and has been done before. actually - people (with the exception of avant-garde experimental noise artists) should just quit playing music because it's ALL been done before by someone, somewhere.
steve: any luck?
unfed: thank you. i will look into that track. |
Unfed
G2 patch files: 11
Posted: Fri Jun 16, 2006 3:47 pm Post subject:
just noticed where i'd heard it. there a breakdown in 'Love in Vein' off Last Rights. i'll try to get you a clip if you can't find it. it's not exactly the same, but pretty close. i'll see if this was used any more on the album. i didn't notice it on Too Dark Park at all, i was wrong on that.
listening to 'Anger' right now. there's a lot going on, but it's not very close to the Patton example and the pitch-shifting doesn't go near as low. _________________ SoundCloud |
Audio files: 21
Posted: Fri Jun 16, 2006 3:57 pm Post subject:
I don´t know that device well, but an old trick with stereo devices of this class is to send like R out to L in .... see...  _________________ A Charity Pantomime in aid of Paranoid Schizophrenics descended into chaos yesterday when someone shouted, "He's behind you!"
Flickr |
Hyde
Posted: Fri Jun 16, 2006 4:09 pm Post subject:
| elektro80 wrote: | I don´t know that device well, but an old trick with stereo devices of this class is to send like R out to L in .... see...  |
i understand that. but i have whole shows on vid tape and the like. he uses about 10 different effects during the show. all patch changes are done via a MIDI pedal. if R out went to L in - i would think it would affect all his patches. i can try it out though.
still - if this is just pre-delay, pitch shift x 4 with 1 being fed back into itself (would have to be 8 pitch shifters in the G2 so we could get the +/- 2 octaves either direction), panning, and master outs - isn't this totally doable on the G2? maybe we'd have to add a module or two to get us there but has anyone even tried (purpose of this whole thread)? |
Audio files: 21
Posted: Fri Jun 16, 2006 4:13 pm Post subject:
If these effects aren´t partly handled from the FOH, then the kid has some simple mixer there too.
Trivia: it is quite common to have several mics patched up differently. One special efx patch for each mic.. _________________ A Charity Pantomime in aid of Paranoid Schizophrenics descended into chaos yesterday when someone shouted, "He's behind you!"
Flickr |
3phase
G2 patch files: 141
Posted: Fri Jun 16, 2006 4:15 pm Post subject:
| elektro80 wrote: | | Any special reason why you think it should be deleted? |
actually copyrights apply to all informations and pictures...
Its however sometimes important to overlook this copyrights for the sake of the comunity... especially old technical manuals are something you just cant get if some people wouldnt make the effort to scan them and put them on the net... and this is illegal... but however important to conserve the information.
with music however the free use defenetly got overstretched... |
3phase
G2 patch files: 141
Posted: Fri Jun 16, 2006 4:18 pm Post subject:
and to the topic...
the sound of the voice sounds like thru a guitar fuzz pedal...
i know that there are some guitar related algorythms in the se50...
and there are two se 50 versions out there... |
Audio files: 21
Posted: Fri Jun 16, 2006 4:23 pm Post subject:
Yeah. As for tech manuals, true, copyright applies. We can claim fair use and whatever.. and most vendors wont´t mind really because modern marketing theory considers viral models for branding. It is good for the brand to have vintage Boss gear hyped in forums.
As for music, this is rather more complex because a vital part of how legality is judged is based on industry practices. _________________ A Charity Pantomime in aid of Paranoid Schizophrenics descended into chaos yesterday when someone shouted, "He's behind you!"
Flickr |
Audio files: 21
Posted: Fri Jun 16, 2006 4:27 pm Post subject:
Yes, there is distortion. The Shure mic gets a fair beating, the mic preamp is hot.. and the Boss thingie seems damned close to serious clipping.. like one step below. And I will still repeat the idea that the output seems gain managed by a CL device. This can of course be caused by the pattonfeed going to the FOH and there might be a clever guy at the desk. _________________ A Charity Pantomime in aid of Paranoid Schizophrenics descended into chaos yesterday when someone shouted, "He's behind you!"
Flickr |
Audio files: 21
Posted: Fri Jun 16, 2006 4:39 pm Post subject:
If the Q is how to make a G2 patch that emulates this one.. well.. I don´t have a G2 . I am sure it is possible to make a much nicer and cooler effect.
Main point is that I dont think you have to go there and you wouldn´t quite get the analog sound form the G2. _________________ A Charity Pantomime in aid of Paranoid Schizophrenics descended into chaos yesterday when someone shouted, "He's behind you!"
Flickr |
Posted: Fri Jun 16, 2006 5:18 pm Post subject:
| paul e. wrote: |
Distorted Pitch Shifting for Dummies... do they have that book out yet? |
Yeah, it's called the "Yamaha Rex 50 User manual" and it's great. :¬p _________________ Kassen |
Audio files: 21
Posted: Fri Jun 16, 2006 5:56 pm Post subject:
Flickr |
Audio files: 21
Posted: Fri Jun 16, 2006 6:08 pm Post subject:
The effect Hyde is asking for does have a series of very significant signatures. He should have enough leads by now in order to achieve this himself. Some suggestions would even make the effect a lot more enhanced. _________________ A Charity Pantomime in aid of Paranoid Schizophrenics descended into chaos yesterday when someone shouted, "He's behind you!"
Flickr |
paul e.
Posted: Fri Jun 16, 2006 9:51 pm Post subject:
| Hyde wrote: |
yeah i have to admit i was pretty sarcastic there and that was wasn;t neccesary for me to make the point that i did...
and it did not answer your actual question that was regarding the G2.
and then there was the copyright sub-issue in this thread ..
this thread makes for an intersting and odd read if you go back to the first post
but i think the idea i threw out there about 'creating an orginal sound' was valid...albeit OT...something to consider _________________ Spiral Recordings |
Hyde
Posted: Fri Jun 16, 2006 11:51 pm Post subject:
all: the manual scans are from the online pdf manual that you can get from Roland's site. anyone can download it.
elektro: i am doing my best here. i know the nord would sound cleaner and more digital but if i could emulate this effect as closely as possible via the G2X Engine i could get rid of the SE-50 (as its the only reason i purchased it). i have the Boss VF-1 and its 24 bit and sounds 10x better - but doesn't have this pitch shifter x4 +/- 2 octaves patch. this one sound and only this one sound is why i bought the SE-50. there are enough building blocks in the G2 to emulate just about anything in either the SE-50 or VF-1. i truly suck at patching. i have tried and tried periodically for months on both the Micro Modular when i got it and the G2X Engine that is why i asked for help.
paul: i dont know if you've ever seen my setup but i can tell you this. with all the gear i have and the ability to effect, sample, re-effect, resample, and manipulate any parameter of audio or midi in real-time i can and do create textures and effects that are V-E-R-Y original. my gear can be seen here:
Hyde's Gear
all: i have acquired a sound board dub of this show and the song in question. it is a bit cleaner. if interested, pm me. |
seraph
Editor
Audio files: 33
Posted: Sat Jun 17, 2006 12:12 am Post subject:
OT: is there anyone else in Nebraska with an impressive set up like yours  _________________ homepage - blog - forum - youtube
| Quote: | | Don't die with your music still in you - Wayne Dyer |
Hyde
Posted: Sat Jun 17, 2006 1:21 am Post subject:
umm - thank you and no. not to my knowledge. the sp808ex sampler is getting the boot in favor of either my laptop or some Numark CDN-95's as soon as i make some extra money. starting my own business has sorta put the kibosh on new noise gear  |
Posted: Sat Jun 17, 2006 2:22 am Post subject:
| seraph wrote: |
OT: is there anyone else in Nebraska with an impressive set up like yours  |
This week's "Phalic post of the week" award goes to Seraph. _________________ Kassen |
