cheap and easy cv quantizer
Page 2 of 4 [85 Posts]
zipzap
PostPosted: Mon Sep 18, 2006 12:37 am    Post subject: Reply with quote  Mark this post and the followings unread
The AD781s are on their way, as soon as they arrive i´ll have some more questions propably...
Another thing:
This midi cv http://m.bareille.free.fr/mcv628/mcv628.html uses a dac0831.
Do you think it can be substituted by an ad781?
Still not really into that dac stuff. I´m sure you´ll know.
http://www.myspace.com/lorolocoacousticpop
music and transcribed jazz basslines
zipzap
PostPosted: Tue Sep 19, 2006 6:25 am    Post subject: Reply with quote  Mark this post and the followings unread
i´m getting started on this and it drives me cracy!
got the dac from ad now, but all it gives me is not a stair but lots of jumps. It does cover quite a range, so maybe it doesn´t matter as long as it´s 1/12v steps. Don´t know what´s wrong.
The schematic from the first posting got pin 2,3 of the dac connected to ground. With that i don´t get any signal. Leaving them open gave me that nonstair.
Now i´m trying to get the ad781 s&h to do the job and that too doesn´t work.
It´s open all the time. All i have to do is add an inverter to it´s controll input, right?
Man, this gets frustrating...
zipzap
PostPosted: Thu Sep 21, 2006 6:37 am    Post subject: Reply with quote  Mark this post and the followings unread
Dear synth builder
I´m going mad.
I´ve build the stairgenerator just like shown here.
http://www.mindspring.com/~clist/resource/circuits/cv_quant.html
only difference is that i didn´t connect pin 3 of the 7245 called ref out to ground. In that case i got no signal. leaving it open results in the stairs that can be heared in the mp3.
Also the pin 6 of the dac has to go to pin 11 of th 4024, not pin 10.
Pin 10 is labled nc in the datasheet. Simple little mistake in the schematic i guess.
As you can hear when clocked slowly the chip is just like me. It loves mad scientists labortory sounds. That is nice, but not what i want.
Funny enough, when comparing it to a cv and triggering an AD 781 with it (after turning it into a narrow pulse) i get the exact same outut going on. But that´s already one step ahead, first there is another stair to climb.
What could be wrong?
quant.mp3
 Filesize:  184.01 KB
 Duration: 0:16
 Viewed:  2919 Time(s)
Scott Stites
Audio files: 97
PostPosted: Thu Sep 21, 2006 8:25 am    Post subject: Reply with quote  Mark this post and the followings unread
Hey Zipster,
I dig what you're saying - I love a good mad scientist sound as much as anyone, but you're right - it doesn't take a $$ DAC and S&H chip to do it Very Happy
The CD4024 isn't the best choice here, being a ripple counter. It's outputs are going to kind of tumble out like a row of dominos rather than just 'snap' out all at the same time with each clock pulse. This means, while its tumbling, it may excite your comparator, but finish its tumble before the S&H grabs it - this throws you off a step or two.
Not that I think that's what's going on here - to me, it sounds like the S&H pulse is too wide, or it's continually getting retriggered for some reason or another. What you might try doing first is getting a better pulse conditioner on there - for one thing, IMO, those two caps there just don't cut it for a nice, crispy pulse.
I've attached a schemo - if you have a CD40106 handy, you might try the top portion of it to see if it improves things any. It's a pretty quick pulse - adjusting the cap value will widen or narrow it. If you need to play around with delaying it, check out the Klee pulse delay used for the clock delay in Episode 3 of the Klee thread. You can do a similar thing on the first CD40106 stage, right after the comparator.
The bottom part of the circuit shows how you can use two CD4516s to replace the CD4024. The CD4516 is a synchronous counter, and I find two of them to be much better behaved for this app than the single CD4024.
Good luck and take care,
Scott
EDIT IMPORTANT
YIKES! Forgot to put a diode on the input of the first CD40106 stage - this is needed to keep the negative output of the comparator from plastering your CD40106 but good!!!!!!! Put it in, cathode to comparator, anode to CD40106. Put a 100K resistor to ground on the input pin of the CD40106 as well - this will pull it low and keep it from floating around while your comparator is not high.
EDIT 2 - I notice on my quantizer foray, I used values of 560 pF and 47K for the pulse width values shown on the second CD40106 on the schemo.
 Filesize:  40.03 KB
 Viewed:  607 Time(s)
zipzap
PostPosted: Fri Sep 22, 2006 2:28 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi Scott
Thats cool, thank you. So you think my stair not being a stair comes from the 4024? You talked about it´s problems on your homepage, i just didn´t expect it to be such a problem...
Maybe it also has to do with the dac on the breadboard with no blocking cabs and no ground seperation. I´ll check that out. To me diy-synth always has that "no part is critical, it might just sound funny" feel.
Maybe the more i get into stuff like this a different aditude is needed.
The sample i posted was generated from the dacs output, not that of the s&h. I´ll get those other chips today and start over with this. See what comes out.
Scott Stites
Audio files: 97
PostPosted: Fri Sep 22, 2006 6:32 am    Post subject: Reply with quote  Mark this post and the followings unread
That would explain why the S&H sounded like it was being triggered more than once Laughing
I'm not sure it's the CD4024's fault - I do know things were a bit unruly til I got rid of it and went with two synchronous counters. Hope it works out!
Take care,
Scott
bugbrand
PostPosted: Fri Sep 22, 2006 7:39 am    Post subject: Reply with quote  Mark this post and the followings unread
Is the LF398 very similar in behaviour to the AD781? 'cos I had to make a pulse width narrower for such an app in the bugcrusher
See the schematic here - uses 22p and 22k to ground - that was about the lowest I could go - stopped all bleed through too
http://www.bugbrand.co.uk
Scott Stites
Audio files: 97
PostPosted: Fri Sep 22, 2006 8:24 am    Post subject: Reply with quote  Mark this post and the followings unread
I'm not sure that bleedthrough is going to be function of pulsewidth, but rather a function of whether your sample pulse is high or low and how well the IC functions when it's supposed to be holding. It can also be a function of how quickly the S&H reacts to a high or low, but I imagine that point is moot, owing for the fact that S&H ICs are designed to react very, very quickly.
The S&H IC, be it an AD781 or LM398, allow, when the pulse is high, anything to pass through and when the pulse is low, it blocks all input and the output's high impedance prevents the cap from discharging. The LM398 can be configured to do the opposite, of course (block when high and pass when low). I imagine the AD781 can be configured likewise?
Anyway, if theres a way to short across the cap that differentiates the incoming high into a short pulse, it converts the function to a 'track and hold' - as long as the input is high, the input passes through unimpeded and, when it's low, the output 'freezes' (a very fun function, BTW - imagine an LFO sweeping, freezing at a certain point, begining its sweep from a different point, freezing, ad nauseum). It's a simple mod for a lot of S&H's out there.
Back to the issue of pulsewidth - if the input is wiggling around a lot and the S&H pulse is wide enough so that the ear can detect that wiggle, you'll hear that on the output. The Buchla 266 SOU S&H does just that - it's got a pretty wide S&H pulse width - somewhere around a ms IIRC. If one is feeding it a very fast signal, such as a VCO or anything moving at an audio rate, one or more cycles can pass through during the time the sample pulse is high. This translates more to a percussive attack at each sample rather than as a discrete tone - not enough of the signal gets through for the ear to decode it as pitch.
Of course, one can also make the input pulse too narrow for the cap its supposed to charge - in this case, its output shuts off before the cap has had a chance to charge/discharge fully to the S&H output.
I use the LM398 mainly because they're easy to get hold of here and cheaper than the AD781. They seem to do just fine. If you go into mass production with the crusher, you might see if it fits the bill - it would lower BOM cost if anything.
Cheerio,
Scott
zipzap
PostPosted: Fri Sep 22, 2006 11:58 am    Post subject: Reply with quote  Mark this post and the followings unread
For modulation sources that behavior of the s&h ics can be very usefull.
Can be used like a kind of "switch and hold"
A slow lfo is passing. Each time the controll goes low the lfo seems to be stopped, when the controll goes high again the lfo seems to continue from a different point.
Ok, i get multiple triggers because my "stair" is jumping across the cv all the time. Seems logic. I thought it wouldn´t matter if it´s actually a stair or jumping around, as long as all semitones are present. Didn´t think enough there... All understood.
AD was so kind to send me two of the dacs, since they both act the same it has to be either the 4024 or my double checking the wireing still missing something.
Scott, i saw on your page that you sent pin3, "ref out" to some opamp circuitry. What´s it for?
Scott Stites
Audio files: 97
PostPosted: Fri Sep 22, 2006 12:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi ZipZap,
Pin 3 is the +5V reference output of the DAC. I buffer and invert it to provide a 5V offset to center the staircase at 0V - this is for bipolar operation.
Cheerio,
Scott
Coriolis
PostPosted: Sat Sep 23, 2006 12:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
Don't mean to hijack the thread, but I have a general question about quantizers: I've been looking at the quantizer designed by Scott Stites http://mypeoplepc.com/members/scottnoanh/birthofasynth/id15.html
and was wondering about the basic operation of this. Is it correct, that if I have, say, a 4 ch sequencer, then I can take the summed output of each and put them through separate channels of the quantizer, and get 4 different melodic lines for instance?
Or is it the other way round - every step of, say, a single 8 step sequencer, needs it's own quantizer channel?
A bit confused as you can see! Sorry again for hijacking, but I feel I'm missing the finer points of this excellent thread!
C
Scott Stites
Audio files: 97
PostPosted: Sat Sep 23, 2006 6:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi Coriolis,
Each channel of the quantizer will quantize its input signal individually. Say you put a sequencer into channel 1, and LFO into channel 2 and a sample and hold into channel 3.
Channel 1 will output the quantized sequencer voltage, channel 2 will output the quantized LFO voltage and channel 3 will output the quantized S&H voltage.
I've been meaning to redesign that quantizer with less range - 10 octaves puts very narrow decision points in there, almost too narrow.
Scott
zipzap
PostPosted: Sun Sep 24, 2006 2:53 am    Post subject: Reply with quote  Mark this post and the followings unread
Hey guys, know what was wrong? I do (someone in a german electronics forum did). In the shematic all outs of the 4024 have to be connected in opposite direction (and use pin11, not 10 on the 4024).
So q1 goes to db0, not db11... q2 to db1 and so on.
Now i´ve got a nice stair. The lowest step is a bit longer than the others, don´t know if that´s a problem though.
Disconnecting some of the steps makes new scales.
Sometimes it´s so easy.
Now i move on to the comp section.
zipzap
PostPosted: Sun Sep 24, 2006 3:33 am    Post subject: Reply with quote  Mark this post and the followings unread
It works!
Got the right puse, now the s&h is doing it´s thing. Tomorrow i´ll get those 4516s and start trimming the whole thing for best performance.
Right now everything is slightly out of tune...
Coriolis
PostPosted: Sun Sep 24, 2006 6:32 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for the explanation Scott! May I suggest about 5-6 octaves then?
C
Scott Stites
Audio files: 97
PostPosted: Mon Sep 25, 2006 7:31 am    Post subject: Reply with quote  Mark this post and the followings unread
Yup - that's the range I was thinking.
Scott
zipzap
PostPosted: Tue Sep 26, 2006 3:33 am    Post subject: Reply with quote  Mark this post and the followings unread
How do you lower the range?
Coriolis
PostPosted: Tue Sep 26, 2006 7:54 am    Post subject: Reply with quote  Mark this post and the followings unread
Yeah, is it just a matter of plopping a resistor on either end of the trimmer to limit range, or... Question
Cos then we could do it ourselves, and you could concentrate on the Super Klee... Laughing
C
Scott Stites
Audio files: 97
PostPosted: Tue Sep 26, 2006 9:33 am    Post subject: Reply with quote  Mark this post and the followings unread
I was afraid someone would ask that question Very Happy Last year I could have answered it right off the top of my head, but now I have to remember what the idea was....
I'll chew on it for a bit here.
Cheerio,
Scott
PostPosted: Thu Sep 28, 2006 6:16 am    Post subject: Reply with quote  Mark this post and the followings unread
hi zip zap,
i want to try that circuit, too. (including the improvements scott and you suggested). what OPA you're using for the oscillator/clock? or do you use the schmitt triggers scott suggested?
zipzap
PostPosted: Sat Sep 30, 2006 8:42 am    Post subject: Reply with quote  Mark this post and the followings unread
I´m using a 4584 for the clock.
PostPosted: Sat Sep 30, 2006 9:51 am    Post subject: Reply with quote  Mark this post and the followings unread
4584? a hex schmitt trigger or a genlock (pll)?
zipzap
PostPosted: Sun Oct 01, 2006 1:12 am    Post subject: Reply with quote  Mark this post and the followings unread
the trigger. It´s propably not that critical anyhow, speed is not that fast and those counters should be easy to clock.
zipzap
PostPosted: Sat Oct 14, 2006 2:27 am    Post subject: Reply with quote  Mark this post and the followings unread
Just came back to this, been away for a while.
It´s not working. Overtested chaining those 4516s. On breadboard, on pcb. The clock is ticking, but the 4516s outs are all high. What could be wrong? somebody got an idea?
Thanks
PostPosted: Sat Oct 14, 2006 3:59 am    Post subject: Reply with quote  Mark this post and the followings unread
Have you got the "Carry In" input held low? If it isn't it won't clock.
