Recent Changes - Search:
go to the forum
Contents
Site
Help
« feb 2026 · jun 2026 »
    add a calendar item
    PmWiki / Tables
    authors (basic)
    Table basics
    PmWiki has two types of table markup; the markup described in this page is useful for creating simple tables with lots of small cells, while table directive markups help with larger scale tables. For more possibilities with table formatting see Cookbook:Rowspan in simple tables and Cookbook:Formatting tables.
    Tables are created via use of double pipe characters: ||. Lines beginning with this markup denote rows in a table or a formatting line. Within table row lines the double-pipe is used to delimit cells. In the examples below a border is added for illustration (the default is no border).
    The first line in the markup contains formatting commands for the table. It only has double pipe characters at the start of the line.
    Basic table
    || border=1
    || cell 1 || cell 2 || cell 3 ||
    || cell 1 || cell 2 ||
    cell 1cell 2cell 3
    cell 1cell 2
    Header cells can be created by placing ! as the first character of a cell. Note that these are table headers, not headings, so it doesn't extend to !!, !!!, etc.
    Table headers
    || border=1
    ||! cell 1 ||! cell 2 ||! cell 3 ||
    cell 1cell 2cell 3
    cell 1cell 2cell 3
    A table can have a caption, indicated by ||!caption!||. Any caption must appear prior to other rows of the table.
    Table caption
    || border=1
    ||! A special table !||
    A special table
    cell 1cell 2cell 3
    cell 1cell 2cell 3
    Formatting cell contents
    Cell contents may be aligned left, centered, or aligned right.
    • To left-align contents, place the cell contents next to the leading ||.
    • To center contents, add a space before and after the cell contents.
    • To right-align contents, place a space before the cell contents and leave the cell contents next to the trailing ||.
    Cell alignments
    || border=1 width=100%
    ||!cell 1      ||! cell 2  ||!       cell 3||
    ||left-aligned || centered || right-aligned||
    cell 1cell 2cell 3
    left-alignedcenteredright-aligned
    Default cell alignments
    || border=1 width=100%
    ||!cell default||!cell left ||
    ||default-aligned||left-aligned ||
    cell defaultcell left
    default-alignedleft-aligned
    Note that header and detail cells have different default alignments.
    To get a cell to span multiple columns, follow the cell with empty cells. (At present there is no markup for spanning rows.)
    Column spanning
    || border=1 width=100%
    || |||| right column ||
    || || middle column ||||
    || left column ||||||
    || left column || middle column || right column ||
     right column
     middle column
    left column
    left columnmiddle columnright column
    Table attributes
    Any line that begins with || but doesn't have a closing || sets the table attributes for any tables that follow. These attributes can control the size and position of the table, borders, background color, and cell spacing. (In fact these are just standard HTML attributes that are placed in the <table> tag.)
    Use the width= attribute to set a table's width, using either a percentage value, an absolute size, or *.
    Table width
    || border=1 width=100%
    || c1 || cellcellcellcell2 || cell 3 ||
    cell 1cell 2cell 3
    c1cellcellcellcell2cell 3
    The border= attribute sets the size of a table's borders.
    Bordered table
    || border=10 width=70%
    cell 3||
    right-aligned||
    cell 1cell 2cell 3
    Borderless table
    || border=0 width=70%
    cell 3||
    right-aligned||
    cell 1cell 2cell 3
    Use align=center, align=left, and align=right to center, left, or right align a table. Note that align=left and align=right create a floating table, such that text wraps around the table.
    Table alignment: center
    || border=1 align=center width=50%
    Notice how text does not wrap with a table using "align=center".
    cell 1cell 2cell 3
    Table alignment: left
    || border=1 align=left width=50%
    Notice how text wraps to the right of a table using "align=left".
    cell 1cell 2cell 3
    Table alignment: right
    || border=1 align=right width=50%
    Notice how text wraps to the left of a table using "align=right".
    cell 1cell 2cell 3
    Note: to get a table to align left (but not "float left") requires CSS, as in
    ||style="margin-left:0px;"
    The bgcolor= attribute sets the background color for a table. At present there is no way to specify the color of individual rows or cells in this type of table (but see Cookbook:FormattingTables).
    || border=1 align=center bgcolor=yellow
    width=70%
    ||left-align || center  || right-align||
    cell 1cell 2cell 3
    left-aligncenterright-align
    How do I create a basic table?
    Tables are created via use of the double pipe character: ||. Lines beginning with this markup denote rows in a table; within such lines the double-pipe is used to delimit cells. In the examples below a border is added for illustration (the default is no border).
    Basic table
    || border=1 rules=rows frame=hsides
    cell 1cell 2cell 3
    cell 1cell 2cell 3
    How do I create cell headers?
    Table headers
    || border=1 rules=cols frame=vsides
    cell 1cell 2cell 3
    cell 1cell 2cell 3
    How do I obtain a table with thin lines and more distance to the content?
    "Thin lines" is tricky and browser dependent, but the following works for Firefox and IE (Nov. 2009):
    Thin lines and cell padding
    ||border="1"
    style="border-collapse:collapse"
    cellpadding="5" width=66%
    ||!Header ||! Header || '''Header'''||
    ||cells   ||  with   ||      padding||
    HeaderHeaderHeader
    cellswithpadding
    How do I create an advanced table?
    See table directives
    My tables are by default centered. When I try to use '||align=left' they don't align left as expected.
    Use ||style="margin-left:0px;" instead.
    How can I specify the width of columns?
    You can define the widths via custom styles, see Cookbook:FormattingTables and $TableCellAttrFmt. Add in config.php : $TableCellAttrFmt = 'class=col$TableCellCount';
    And add in pub/css/local.css :
    table.column td.col1 { width: 120px; }
    table.column td.col3 { width: 40px; }
    How can I display a double pipe "||" in cell text using basic table markup?
    Escape it with [=||=] to display || unchanged.
    How to I apply styles to the elements of the table, like an ID to the table row, or a class/style to the TD?
    See $WikiStyleApply.
    This page may have a more recent version on pmwiki.org: PmWiki:Tables, and a talk page: PmWiki:Tables-Talk.
    Edit - History - Print - Recent Changes - Search Page last modified on 2011-09-10 12:08 [UTC-7] - 398 views
