Recent Changes - Search:
go to the forum
Contents
Site
Help
« feb 2026 · jun 2026 »
    add a calendar item
    Schematics / Sawtooth To Triangle Converter
    < VCF by Phobos | Schematics | VCA1 linear-exponential by >
    < Ballanced Modulator aka Ringmodulator | Listbytype | 80-11 Dual Ring Modulator >
    DIY | Wave Shaping | Saw | Triangle | Scott Gravenhorst | 4069 | René Schmitz
    Sawtooth to Triangle Converter by Scott Gravenhorst ,visit his page for more circuits and modifications http://home1.gte.net/res0658s/fatman/saw_to_tri_converter.html from there the notes by Scott :
    This wave shaper needs an input saw that goes from Vss to (ideally) Vdd. It works well with the 4069 VCO designed by René Schmitz. Any saw will work as long as the wave is centered halfway between the rails. It works as follows: The upper set of 2 linear mode gates provide an inverted and noninverted copy of the saw. The 3 logic gates at the bottom provide a sort of comparator that switches at halfway between the rails. The 4007 provides 2 P-MOSFETs that alternately select the inverted or noninverted saw signal depending on where the saw is in it's cycle. This causes the ramp to reverse directions every half cycle. Any imperfection in the saw will show up in the resulting output. The linear mode gate furthest to the right provides soft clipping that turns the triangle wave into something like a sine wave. It sounds like it has fewer harmonics than the triangle.
    Edit - History - Print - Recent Changes - Search Page last modified on 2013-02-24 17:12 [UTC-7] - 5087 views
