Audio files: 97
Posted: Thu Oct 18, 2007 7:48 am Post subject:
The rotary switch I used in my Klee would be perfect for a more compact design - it's an NKK that is no wider than those tiny Alpha pots I use. It's a very sweet little rotary switch.
The 'utility modules' are kind of boring to build, but suprisingly an important part of a modular system if one wants flexibility.
Man, that is so very true. It's the mixers and such that really open up a modular. A few well placed mixers will turn a muscle-bound Mr. Universe modular into a lithe Jackie Chan powerhouse in no time flat.
Audio files: 97
Posted: Thu Oct 18, 2007 7:50 am Post subject:
"electro-music Klee Sequencer Composite BOM for Digital and Analogue Boards". Is this accurate? Im referring to it for the parts I need. Mostly the pots and switches. I ordered a kit, so I only have a few other parts I need to order.
The appendix of the build doc would be the most up to date list, I think.
Posted: Thu Oct 18, 2007 10:20 am Post subject:
Electronic Happiness
Another sample with the same basic patch and module setup as "Metallic Air" but I like this one better. Mostly changes in the VCO pitches, EG settings and bit pattern loading.
Joined: Nov 18, 2006 Posts: 236 Location: San Francisco, CA bay area
Posted: Thu Oct 18, 2007 1:32 pm Post subject:
Thanks Fonik for posting that panel. I really like it. I think I may just use your design. One important question though. I know you use 1/8" jacks, but im using 1/4" jacks. Will 1/4" jacks fit on your panel the way it is designed?
Also im ordering mini switches. Should I order sub mini switches?
pete, i think i posted the fpd file in the super klee sequencer thread. i am not quite sure, though. if desired i could post it again, then you could play with the layout and measure the space between the components... _________________
Is that 32 step (16X1, Invert B) right there around the 2:27 mark?
I definately used the (16X1, Invert B) mode somewhere around that area but I not sure where I kicked it in and out. I was just kind of winging it...if you know what I mean
Audio files: 25
Posted: Thu Oct 18, 2007 4:58 pm Post subject:
Yes, mixers and don't forget multies. My system is definitely lacking in the multi and mixer department. I want to make a multi panel that will also transition from 1/4" to 1/8" jacks without using any adapters on the patch cables.
I did not want to reinvent the wheel so I purchased the Blacet Mixer Processor. Very nice module. I may get a couple more of these.
Posted: Thu Oct 18, 2007 10:00 pm Post subject:
CataKleesmic
OK,
This is the last sample for a while...I promise. This one felt so good I couldn't stop. It is much better behaved (and tuned ) than the last sample and was recorded in one pass clock synced to the Dr-5 drums again. The Klee is controlling all of the melody and bass parts.
Audio files: 97
Posted: Fri Oct 19, 2007 10:20 am Post subject:
Dang, I love these, too! You're definitely going into uncharted territory now - I had no idea the Klee could mesh so well with MIDI controlled anything.
I'm gonna have to consult with you on this manual, you're writing chapters I haven't thought of yet.
Audio files: 25
Posted: Sat Oct 20, 2007 10:32 am Post subject:
I have just received the version 1.22 Klee printed circuit board set from Scott and they look fantastic. Scott and I are doing the final QA build on these board sets to assure their accuracy and quality. Of course, everyone is very anxious to get their boards, parts and documentation to get started on their projects. It's getting very close. With any luck, If my parts balance ordered is in stock and I get my deliveries by next Wednesday, I should start shipping some of the parts kits by Saturday, October 27.
I have sold 45 full EM- Klee parts kits in the past three or four weeks and just wanted to throw out some numbers of just how many components that actually comes out to.
Hmmm,...
After seeing all the numbers laid out like that,
I have a whole new understanding of the concept of tolerance. _________________ What makes a space ours, is what we put there, and what we do there.
Yeah, I ended up very pleased with them. I s'pose it's only on a project as big as this where prototypes are checked out that you're able to go back in and finesse just a little more. If I had the chance to do them over again, there isn't much I'd change. This has taught me heaps about PCB design. _________________ What makes a space ours, is what we put there, and what we do there.
