Coming up on Radio 1 at
Electro-Music Klee Sequencer Build and Applications Thread
Page 27 of 54 [1348 Posts]
Goto page: Previous 1, 2, 3, ..., 25, 26, 27, 28, 29, ..., 52, 53, 54 Next
Scott Stites
Audio files: 97
PostPosted: Thu Oct 18, 2007 7:48 am    Post subject: Reply with quote  Mark this post and the followings unread
The rotary switch I used in my Klee would be perfect for a more compact design - it's an NKK that is no wider than those tiny Alpha pots I use. It's a very sweet little rotary switch.
The 'utility modules' are kind of boring to build, but suprisingly an important part of a modular system if one wants flexibility.
Man, that is so very true. It's the mixers and such that really open up a modular. A few well placed mixers will turn a muscle-bound Mr. Universe modular into a lithe Jackie Chan powerhouse in no time flat.
Scott
My Site
Scott Stites
Audio files: 97
PostPosted: Thu Oct 18, 2007 7:50 am    Post subject: Reply with quote  Mark this post and the followings unread
"electro-music Klee Sequencer Composite BOM for Digital and Analogue Boards". Is this accurate? Im referring to it for the parts I need. Mostly the pots and switches. I ordered a kit, so I only have a few other parts I need to order.
The appendix of the build doc would be the most up to date list, I think.
Scott
My Site
Alienation
PostPosted: Thu Oct 18, 2007 8:59 am    Post subject: Reply with quote  Mark this post and the followings unread
What is the part number for the NKK rotary switch? If I may ask.
I'm using 16mm pots and the enclosure I'm using is what I would call compact.
Thanks
Scott Stites
Audio files: 97
PostPosted: Thu Oct 18, 2007 10:15 am    Post subject: Reply with quote  Mark this post and the followings unread
The datasheet for the switch can be found here:
NKK Rotary Switch PDF
Not cheap, but well worth it. I got it at Allied Electronics here
Scott
[Edit Blue Hell: shortened the link]
My Site
THeff
Audio files: 33
PostPosted: Thu Oct 18, 2007 10:20 am    Post subject: Electronic Happiness Reply with quote  Mark this post and the followings unread
Another sample with the same basic patch and module setup as "Metallic Air" but I like this one better. Mostly changes in the VCO pitches, EG settings and bit pattern loading.
Tim
Electronic Happiness.mp3
 Filesize:  2.06 MB
 Duration: 4:30
 Viewed:  2750 Time(s)
Scott Stites
Audio files: 97
PostPosted: Thu Oct 18, 2007 10:30 am    Post subject: Reply with quote  Mark this post and the followings unread
Holy S**t!!
Just in time for lunch break, too - Tim, I love this one!!
My Site
Scott Stites
Audio files: 97
PostPosted: Thu Oct 18, 2007 10:37 am    Post subject: Reply with quote  Mark this post and the followings unread
Is that 32 step (16X1, Invert B) right there around the 2:27 mark?
My Site
Alienation
PostPosted: Thu Oct 18, 2007 11:17 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for the info.... Very Happy
Another interesting sample posted for our entertainment.... Cool
I can see where the patch sheets will be a necessity...it would be a shame to lose the settings for what this thing can do.
Good stuff man...
23isgood
PostPosted: Thu Oct 18, 2007 1:32 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Fonik for posting that panel. I really like it. I think I may just use your design. One important question though. I know you use 1/8" jacks, but im using 1/4" jacks. Will 1/4" jacks fit on your panel the way it is designed?
Also im ordering mini switches. Should I order sub mini switches?
thanks,
pete
Check out my music
PostPosted: Thu Oct 18, 2007 2:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
pete, i think i posted the fpd file in the super klee sequencer thread. i am not quite sure, though. if desired i could post it again, then you could play with the layout and measure the space between the components...
Posted Image
THeff
Audio files: 33
PostPosted: Thu Oct 18, 2007 2:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hey Scott,
I definately used the (16X1, Invert B) mode somewhere around that area but I not sure where I kicked it in and out. I was just kind of winging it...if you know what I mean Confused
Regards,
Tim
Audio files: 25
PostPosted: Thu Oct 18, 2007 4:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yes, mixers and don't forget multies. My system is definitely lacking in the multi and mixer department. I want to make a multi panel that will also transition from 1/4" to 1/8" jacks without using any adapters on the patch cables.
I did not want to reinvent the wheel so I purchased the Blacet Mixer Processor. Very nice module. I may get a couple more of these.
http://blacet.com/MX.html
23isgood
PostPosted: Thu Oct 18, 2007 6:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
Fonik, if you could post the .fpd for your panel I would appreciate it.
thanks,
pete
Check out my music
THeff
Audio files: 33
PostPosted: Thu Oct 18, 2007 7:14 pm    Post subject: KleeMidi Reply with quote  Mark this post and the followings unread
Here is a wacky sample of the Klee clocked from a divided down MIDI clock from a DR-5 drum machine...oh well what I say?
Regards,
Tim
KleeMidi.mp3
 Filesize:  1.57 MB
 Duration: 3:26
 Viewed:  2679 Time(s)
THeff
Audio files: 33
PostPosted: Thu Oct 18, 2007 10:00 pm    Post subject:  CataKleesmic Reply with quote  Mark this post and the followings unread
OK,
This is the last sample for a while...I promise. This one felt so good I couldn't stop. Razz It is much better behaved (and tuned Confused ) than the last sample and was recorded in one pass clock synced to the Dr-5 drums again. The Klee is controlling all of the melody and bass parts.
Tim
CataKleesmic.mp3
 Filesize:  2.29 MB
 Duration: 5:00
 Viewed:  2730 Time(s)
PostPosted: Thu Oct 18, 2007 10:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
here is the 2U panel. it is from the old super klee sequencer thread, so the GUI does not necessary reflect the options of the current klee2 PCBs...
klee2_2U.zip
KLEE2 19''/2U schaeffer front panel designer file (.fpd)
 Filename:  klee2_2U.zip
 Filesize:  6.07 KB
 Downloaded:  297 Time(s)
Posted Image
Former site admin
Audio files: 353
PostPosted: Fri Oct 19, 2007 5:22 am    Post subject: Re: CataKleesmic Reply with quote  Mark this post and the followings unread
Nice ones !
View user's profile
Scott Stites
Audio files: 97
PostPosted: Fri Oct 19, 2007 10:20 am    Post subject: Reply with quote  Mark this post and the followings unread
Dang, I love these, too! You're definitely going into uncharted territory now - I had no idea the Klee could mesh so well with MIDI controlled anything.
I'm gonna have to consult with you on this manual, you're writing chapters I haven't thought of yet.
Shocked Noooooooo.....!
My Site
Audio files: 25
PostPosted: Sat Oct 20, 2007 10:32 am    Post subject: Reply with quote  Mark this post and the followings unread
I have just received the version 1.22 Klee printed circuit board set from Scott and they look fantastic. Scott and I are doing the final QA build on these board sets to assure their accuracy and quality. Of course, everyone is very anxious to get their boards, parts and documentation to get started on their projects. It's getting very close. With any luck, If my parts balance ordered is in stock and I get my deliveries by next Wednesday, I should start shipping some of the parts kits by Saturday, October 27.
I have sold 45 full EM- Klee parts kits in the past three or four weeks and just wanted to throw out some numbers of just how many components that actually comes out to.
Resistors 6390
Capacitors 2160
Diodes 1665
Transistors 270
Integrated Circuits 1125
Sockets 1080
Headers 1260
Connector Housings 1260
Crimp Terminals 8550
Trimmers 450
Total Components : 24210
Gee, I hope they all work Shocked
Bill
Alienation
PostPosted: Sat Oct 20, 2007 10:56 am    Post subject: Reply with quote  Mark this post and the followings unread
Me too!! Very Happy
fluxmonkey
PostPosted: Sat Oct 20, 2007 1:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
State Machine wrote:
Resistors 6390
Capacitors 2160
Diodes 1665
Transistors 270
Sockets 1080
Headers 1260
Trimmers 450
Bill
hope? you mean you aren't going to test them all before shipping??
b
PostPosted: Sat Oct 20, 2007 2:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hmmm,...
After seeing all the numbers laid out like that,
I have a whole new understanding of the concept of tolerance. Wink
Audio files: 25
PostPosted: Sat Oct 20, 2007 3:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hmmm,...
Yes Andy and thats only for 45 kits. It could go higher Very Happy Hell, it's a good cause !! Very Happy
BTW, nice job on the Version 1.22 boards !!! Cool Cool
Bill
Audio files: 25
PostPosted: Sat Oct 20, 2007 3:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
OMG !!!! Shocked
PostPosted: Sat Oct 20, 2007 6:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yeah, I ended up very pleased with them. I s'pose it's only on a project as big as this where prototypes are checked out that you're able to go back in and finesse just a little more. If I had the chance to do them over again, there isn't much I'd change. This has taught me heaps about PCB design.
